Confusing UVM_ERROR in uvm_reg_bit_bash_seq
I’m having this error in register bit bash and it confuses me:
UVM_ERROR [uv_reg_bit_bash_seq] Writing a 0 in bit #0 of register “reg_model.memmap0.MODE_SET1” with initial value 'h0001 yielded 'h0000 instead of 'h0001
I don’t think this is an error because a value of 0 is being written and the yielded value is 0. So there should be no problem with that.
Can someone tell me if I understand this UVM_ERROR correctly?
Hello,
its depend on the permission of that register, this would be only true if register/field is RW in nature.
after looking into UVM_ERROR I believe,permission of reg/field is RO
so,
initial value = 0001
expected value after writing 0 on #0 bit = 0001 (as RO)
actual value which you got = 0000 (because of it got written on register #0th bit even though its RO)
if this is not case, please share register code for ‘MODE_SET1’
Regards,
Vinay Jain
In reply to Reuben:
Hi Reuben,
Did you find any solution for this issue ?
Because I am also facing same issue !!
Thanks in advance !!
Regards,
Dhaval
I was able to get rid of the error by sending responses from the driver only on reads, and not on writes
Hi, I have the same problem. My register is a RW access register. So I am not sure what the problem can be.
