Confused between $cast and factory override
dear all,
I’m trying to understand difference between $cast and override.
And I came across good example as the below
module test_module ();
`include "uvm_macros.svh"
  class agent_a extends uvm_agent;
    `uvm_component_utils(agent_a)
    function new(string name = "agent_a", uvm_component parent = null);
    endfunction : new
  endclass : agent_a
  class agent_b extends agent_a;
    `uvm_component_utils(agent_b)
    string field = "field";
    function new(string name = "agent_b", uvm_component parent = null);
    endfunction : new
  endclass : agent_b
  agent_a agent_a_h;
  uvm_agent temp;
  agent_b agent_b_h;
  agent_a agent_a_h_2;
  int cast1, cast2, cast3;
    agent_a::type_id::set_type_override(agent_b::get_type());
    factory.print();
    agent_a_h = agent_a::type_id::create("agentti_h", null);
    temp = agent_a_h;
    cast1 = $cast(agent_a_h_2, agent_a_h); // This $cast works also with type override, why?
    cast2 = $cast(agent_b_h, agent_a_h);  // This $cast won't work without type override, why?
    cast3 = $cast(agent_b_h, temp);  // This $cast won't work without type override either.
    $display("casts = ", cast1, cast2, cast3);
    $display("field = ", agent_b_h.field);
endmodule : test_module
As I understand, step by step
1.requested type agent_a and override type agent_b. so agent_a is agent_b.
2.agent_a_h is created by agent_b not agent_a because type override.
so we can assume that agent_a agent_a_h is agent_b agent_a_h and agent_a agent_a_h_2 is agent_b agent_a_h_2
  1. cast1 is the same as agent_b class’s agent_a_h_2 and agent_b class’s agent_a_h.
    so they are same object type. no problem.
  2. cast2 is the same as agent_b class’s agent_b_h and agent_b class’s agent_a_h.
  3. This cast3 didn’t get it. how does cast between agent_b and uvm_agent?
    When I ran the Simulation, There is no Error.
    And What is the point the difference between cast and override? I couldn’t find it.
https://www.edaplayground.com/x/Gpce
Could you guide me?
In reply to UVM_LOVE:
after doing type override agent_a with agent_b, then while creating agtent_a object using create method actually it creates object for agent_b and returns handle of agent_b (note: this handled by UVM DB and factory override)
3. cast1 is the same as agent_b class’s agent_a_h_2 and agent_b class’s agent_a_h.
Yes…
cast2 = $cast(agent_b_h, agent_a_h); // This $cast won’t work without type override, why?
it won’t work because without override, agent_a_h variable contains the class handle(i.e. object instance memory location) for agent_a, so…agent_b_h and agent_a_h are different class types and hence it won’t work
In reply to Desam:
    Yes…
Thanks reply,
But If you can see the result in my EDAPLAYFROUND link, cast1, cast2, cast3 are all 1.
Meaning that All casts are working as well, I don’t understand especially cast2 and cast3.
I did see below results from eda playground:
with type override: agent_a::type_id::set_type_override(agent_b::get_type()); //enabling
casts = 1 1 1
without type override: // agent_a::type_id::set_type_override(agent_b::get_type()); //commented it out
casts = 1 0 0
i did see expected results here…
In reply to Desam:
casts = 1 1 1
casts = 1 0 0
Yes. I got the same result.
Could you let me know Handle type and Object Type from the below?
agent_a agent_a_h;
uvm_agent temp;
agent_b agent_b_h;
I think there is no Objection Type.
Handle Types are
agent_a ;
uvm_agent ;
agent_b ;
agent_a ;
Am I right?
Handle Types are
agent_a ;
uvm_agent ;
agent_b ;
agent_a ;
Am I right?
no, these are class Types which contains set of members and set of methods that operate on those members
agent_a_h,agent_b_h,temp : these are class variables where you store the class handles that references a particular class object of a particular class type
more info: A Short Class on SystemVerilog Classes - Verification Horizons
In reply to Desam:
Handle Types are
agent_a ;
uvm_agent ;
agent_b ;
agent_a ;
Am I right?
I see that A Short Class on SystemVerilog Classes - Verification Horizons
But I couldn’t find what I want about Type Object and Handle Object.
Could you give me some example for understanding ?
The answer is very simple:
The 'override is limited to the UVM. SV does not have a override command.
The $cast is a so-caled dynamic type cast. You can use the $cast independently from the UVM and it is doing a type cast to types (classes) which are belonging to the same family.
In reply to Desam:
What is your doubt? cast2 or cast3 or both ??
