Hi all ,
I am trying so set “is_active” variable ( of class uvm_agent ) from 2 Components at Same level of Hierarchy
`include "uvm_pkg.sv"
`include "uvm_macros.svh"
`define COMP_NEW function new ( string name , uvm_component parent ) ; \
super.new(name,parent);\
class agent extends uvm_agent ;
`uvm_component_utils( agent )
`COMP_NEW
int active;
`uvm_info(get_name(),"In build_phase",UVM_NONE)
if( get_config_int("is_active", active) )
`uvm_info(get_name()," get_config_int is Successful !! ",UVM_NONE)
is_active = uvm_active_passive_enum'(active);
class test extends uvm_component ;
`uvm_component_utils( test )
`COMP_NEW
agent ag ;
uvm_config_db#(int)::set(this,"*","is_active",101) ; // Value of 101 set from Test i.e Active ( Since LSB is 1 ) !!
ag = new("ag",this) ;
function void end_of_elaboration_phase ( uvm_phase phase ) ;
uvm_top.print_topology();
class my_class extends uvm_component ;
`uvm_component_utils( my_class )
`COMP_NEW
uvm_config_db#(int)::set(uvm_top,"*","is_active",100) ; // Value of 100 set i.e Passive ( Since LSB is 0 ) !! !!
my_class class_h ;
class_h = new("class_h",null);
run_test("test") ;
Since “class_h” and uvm_test_top i.e test are AT SAME LEVEL OF HIERARCHY , I expected get_config_int to be successful with is_active set to UVM_ACTIVE.
But I notice that in Output get() isn’t successful
Any thoughts ?
Thanks in advance
