Compile Error not pointing to the correct line
Can any one help me with this compile error? It doesnt seem to be pointing to the original failure. Appreciate ur help.
Error-[SE] Syntax error
“testbench.sv”, 418: token is ‘interface’
interface bus_if;
SystemVerilog keyword ‘interface’ is not expected to be used in this
context.
please first try to read your code again you have error on line 212
solved :- Sync FIFO(1) - EDA Playground
In reply to dhaval_sanepara:
Strange as the error was pointing on line 418, the actual error is at line 212.
In reply to rag123:
context.
try to read error not line number given by error, in this case hint is not expected in this context.
In reply to rag123:
Errors like this are always related to a wrong structure in your code, i.e. a missing ‘;’ or an ‘end’.
In you case it is caused by the following piece of code:
class bus_seq_rw extends uvm_sequence;
  `uvm_object_utils(bus_seq_rw)
  rand bit [7:0] data;
The interpretation is a nested class definition, but the corresponding endclass is missing.
To fix remove the 2 lines of code and it will work.
