Hi.
I’m trying to setup the co-verification between reference c++ code and UVM and compare Reference C++'s output and UVM output.
But some current situation is very tricky for me.
- Reference C++ make output vector.
- The output vector from (1) used for UVM simulation.
- Reference C++ operated by randomized constraint variable from UVM.
Problem : UVM simulation Need to regression with randomize but Reference C++ code should be run first by using UVM simulation randomized input variable.
So In this situation, What should I do for Co-Verification between UVM and C++ code?
In reply to UVM_LOVE:
You have to embed your C++ subroutine into a SV component and connect his component to your UVM environment.
Currently, I can’t afford to embed Reference C++ code as subroutine into a SV component. Because That C++ model is came from another company and they don’t know systemverilog as well.
Do I have to breakdown pure c++ code into SV subroutine? such as by using DPI-C techniques?
The answer to your question can be complicated without knowing how the model is structured to be used in a pure C++ environment. Can it be wrapped in a C function? How does it expect input and output to be handled?
Fortunately, I could resolve it with $system() function.
For example,
sys_cmd = {“/user/bin/python3 /user/data/calc.py”, lut_r_sd, pure_tap[0]};
$system(sys_cmd);
like this way.
