I have a CPOL variable inside the test, if I assign CPOL value as 1, the clock should be inverted else I pass 0 to the CPOL, the clock should start at posedge.
How should I do it?
Thanks in advance.
How should I do it?
Thanks in advance.
In reply to A E Aravind:
You can invert any signal by passing through an xor expression
assign clock = ref_clock ^ CPOL;
I am guessing there is more to this question.
