Can we have a TLM ports instead of complete agent?
HI,
I need to configure the modes driving through DUT, i dont want complete dont want to monitor too, just need to drive the modes configuration. Can we have any specific mechanism in UVM or any TLM ports available ?
SANJAIKUMAR
In reply to sanjai_483:
You do not say where the configuration data are coming from. Of course there are different ways to do this. You could simply use a sequencer/driver combination.
Yes, as pointed out in the above reply, you are looking for a passive agent. One way to do so is to use the config objects via uvm_config_db.
Yes we can use simple sequencer/driver, but i dont want to monitor.
From the test, i need to change the mode of the DUT. So can I use uvm_blocking_get_port methodolgy, if i use how to configure from the test.
Thanks in advance
In reply to chiranjeev:
No. I am not looking for monitor. I want to configure DUT to change mode through separate component, I dont want to implement a full agent. Instead Can i use TLM ports ?
Thanks in advance
A few questions to understand you right:
(1) your DUT has a specific pinlevel interface which is used only for configuring the DUT?
(2) This configuration interface is not used for anything else?
In this case you might use an agent without a monitor.
You can specify y configuration test which uses a configuration sequence to configure your DUT.
When you are using a UVM Framework Generator it doesn’t matter to create also a monitor, but you do not implement anything there.
Using the agent architecture helps you for future projects with respect to reusability.
To answer your questions,
  1. MY DUT has specific mode pin level interface used for configuring the DUT
  2. No, Only used for mode configuration.
So, I can create a configuration test which has configuration sequence to configure the DUT through sequencer, driver right ?
I will look into UVM framework generator in detail & get back to you.
Thanks in advance
For the UVM Framework Generator free-of-charge see here:
https://www.doulos.com/knowhow/sysverilog/uvm/
