can we access DUT signals in sequence class? if yes then how?
mukesh
mukesh
In reply to muku_383:
Can you? Yes.
Should you? No. You should only access signals using an agent’s driver or monitor.
You can do this because the UVM does not have compliance rules. But it is useless to do this and it complicates your testbench and the sequence execution.
Hi Muku_383,
Ideally you should not access them from sequence as it kills the reuse feature for next gen Testbench.
But there is a provision.
Then you are able to use that wherever necessary.
