Hi all ,
I have a situation where the configuration of my environment depends on the packet:
Let's say in my header I have a field of 3 bits if the value of that field vary from 0 to 5 we will work in REVERTED mode ( the environment should be in REVERTED mode)
and if the said field is from (5 to 7) the environment should be in NORMAL mode.
I am trying to randomize the field of my packet so I was thinking to set a variable "env_mode" in the body phase of my packet then use the get method in the top environment.
However, the environment is only set once and even if we change the header field the configuration of the environment won't change.
To be honest I was not so eager to use the config_db set method : since the seq_item is a dynamic object I am not sure if it can set things in the config_db.
So my question is it possible to use the config_db set method in the seq_item ? is it possible to change the config of my env from the seq_item ?
