Hi All,
I have a question on uvm_config_db.
Let's say I have two classes, class animal and class cat which is a child class of class animal. I wonder if I can store a cat object to uvm_config_db with the type animal?
Example code:
class animal extends uvm_object;
int age;
class cat extend animal;
string breed;
class sample_test extends uvm_test;
cat c_test;
sample_env env;
function build_phase (uvm_phase phase);
create the object env and c_test
c_test.breed="russian_blue";
uvm_config_db#(animal)::set(this,env,"animal",c_test);
class sample_env extends uvm_env;
cat c_env;
string breed;
function build_phase(uvm_phase phase);
uvm_config_db#(animal)::get(this,"","animal",c_env);
breed=c_env.breed;
I wonder for the above code, can env.breed successfully got the value of "russian_blue"(c_test.breed)?
Thanks in advance!
Hao
