Here is the code for Round robin arbiter testbench. The req doesnt seem to randomize and always drives 0.
module fixed_arb (input [2:0] req, output reg [2:0] grant);
always @ (req)
// case (1'b1) :
if (req[0])
grant = 3'b001;
else if (req[1])
grant = 3'b010;
else if (req[2])
grant = 3'b100;
//end
//endcase
module round_robin_arbiter (input clk,rst,[2:0] req, output [2:0] grant);
logic [2:0] local_grant,raw_grant;
logic [2:0] mask_req ;
logic [2:0] mask;
always @ (posedge clk or negedge rst) begin
if (!rst)
mask <= 3'b111;
else if (grant[0])
mask <= 3'b110;
else if (grant[1])
mask <= 3'b100;
else if (grant [2])
mask <= 3'b000;
assign mask_req = req & mask;
fixed_arb f1(.req(mask_req),.grant(local_grant));
fixed_arb f2(.req(req),.grant(raw_grant));
assign grant = (mask == 3'b000) ? raw_grant : local_grant;
// Code your testbench here
// or browse Examples
class sfr_seq_item extends uvm_sequence_item;
`uvm_object_utils(sfr_seq_item)
function new(string name = "sfr_seq_item");
randc bit[2:0] req;
bit [2:0] grant;
function string convert_to_string();
string s;
s = $sformatf("%t req: %0h", $time(), req);
return s;
endclass: sfr_seq_item
class sfr_test_seq extends uvm_sequence #(sfr_seq_item);
`uvm_object_utils(sfr_test_seq)
function new(string name = "sfr_test_seq");
task body;
sfr_seq_item item = sfr_seq_item::type_id::create("item");
repeat(50) begin
start_item(item);
assert(item.randomize());
`uvm_info("seq_body", item.convert_to_string(), UVM_LOW);
finish_item(item);
endtask: body
endclass: sfr_test_seq
class sfr_config_object extends uvm_object;
`uvm_object_utils(sfr_config_object)
function new(string name = "sfr_config_object");
bit is_active;
virtual sfr_master_bfm SFR_MASTER;
virtual sfr_monitor_bfm SFR_MONITOR;
endclass: sfr_config_object
class sfr_driver extends uvm_driver #(sfr_seq_item);
`uvm_component_utils(sfr_driver)
function new(string name = "sfr_driver", uvm_component parent = null);
virtual sfr_master_bfm SFR;
endclass: sfr_driver
task sfr_driver::run_phase(uvm_phase phase);
sfr_seq_item item;
seq_item_port.get_next_item(item);
SFR.execute(item);
seq_item_port.item_done();
endtask: run_phase
interface sfr_master_bfm(input clk,
input reset,
output logic[2:0] req,
input logic [2:0] grant);
// import sfr_agent_pkg::*;
always @(reset or posedge clk) begin
if(reset == 1) begin
req <= 0;
task execute(sfr_seq_item item);
wait(reset == 0);
else begin
@(posedge clk);
req = item.req;
// Output coming back from the DUT
item.grant = grant;
endtask: execute
endinterface: sfr_master_bfm
class sfr_monitor extends uvm_component;
`uvm_component_utils(sfr_monitor)
function new(string name = "sfr_monitor", uvm_component parent = null);
virtual sfr_monitor_bfm SFR;
uvm_analysis_port #(sfr_seq_item) ap;
endclass: sfr_monitor
function void sfr_monitor::build_phase(uvm_phase phase);
ap = new("ap", this);
endfunction: build_phase
task sfr_monitor::run_phase(uvm_phase phase);
sfr_seq_item item;
SFR.monitor(item);
ap.write(item);
endtask: run_phase
interface sfr_monitor_bfm(input clk,
input reset,
input[2:0] req,
input[2:0] grant);
task monitor(sfr_seq_item item);
@(posedge clk);
item.req = req;
item.grant = grant;
endtask: monitor
endinterface: sfr_monitor_bfm
class sfr_agent extends uvm_component;
`uvm_component_utils(sfr_agent)
uvm_sequencer #(sfr_seq_item) sequencer;
sfr_driver driver;
sfr_monitor monitor;
sfr_config_object cfg;
function new(string name = "sfr_agent", uvm_component parent = null);
extern function void connect_phase(uvm_phase phase);
endclass: sfr_agent
function void sfr_agent::build_phase(uvm_phase phase);
if(cfg == null) begin
if(!uvm_config_db #(sfr_config_object)::get(this, "", "SFR_CFG", cfg)) begin
`uvm_error("BUILD_PHASE", "Unable to find sfr agent config object in the uvm_config_db")
monitor = sfr_monitor::type_id::create("monitor", this);
if(cfg.is_active == 1) begin
driver = sfr_driver::type_id::create("driver", this);
sequencer = uvm_sequencer #(sfr_seq_item)::type_id::create("sequencer", this);
function void sfr_agent::connect_phase(uvm_phase phase);
monitor.SFR = cfg.SFR_MONITOR;
monitor.ap.connect(ap);
driver.SFR = cfg.SFR_MASTER;
endfunction: connect_phase
class sfr_env_config extends uvm_object;
`uvm_object_utils(sfr_env_config)
function new(string name = "sfr_env_config");
sfr_config_object sfr_agent_cfg;
endclass: sfr_env_config
class sfr_env extends uvm_component;
`uvm_component_utils(sfr_env)
function new(string name = "sfr_env", uvm_component parent = null);
sfr_env_config cfg;
//sfr_scoreboard sb;
sfr_agent agent;
endclass: sfr_env
function void sfr_env::build_phase(uvm_phase phase);
if(!uvm_config_db #(sfr_env_config)::get(this, "", "CFG", cfg)) begin
`uvm_error("BUILD_PHASE", "Unable to find environment configuration object in the uvm_config_db")
//sb = sfr_scoreboard::type_id::create("sb", this);
agent = sfr_agent::type_id::create("agent", this);
agent.cfg = cfg.sfr_agent_cfg;
function void sfr_env::connect_phase(uvm_phase phase);
// agent.ap.connect(sb.analysis_export);
class sfr_test extends uvm_component;
`uvm_component_utils(sfr_test)
function new(string name = "sfr_test", uvm_component parent = null);
sfr_env_config env_cfg;
sfr_env env;
endclass: sfr_test
function void sfr_test::build_phase(uvm_phase phase);
env_cfg = sfr_env_config::type_id::create("env_cfg");
sfr_agent_cfg = sfr_config_object:: type_id::create("sfr_agent_cfg");
if(!uvm_config_db #(virtual sfr_master_bfm)::get(this, "", "SFR_MASTER", sfr_agent_cfg.SFR_MASTER)) begin
`uvm_error("BUILD_PHASE", "Unable to find virtual interface sfr_master_bfm in the uvm_config_db")
if(!uvm_config_db #(virtual sfr_monitor_bfm)::get(this, "", "SFR_MONITOR", sfr_agent_cfg.SFR_MONITOR)) begin
sfr_agent_cfg.is_active = 1;
env_cfg.sfr_agent_cfg = sfr_agent_cfg;
env = sfr_env::type_id::create("env", this);
env.cfg = env_cfg;
task sfr_test::run_phase(uvm_phase phase);
sfr_test_seq seq = sfr_test_seq::type_id::create("seq");
phase.raise_objection(this);
seq.start(env.agent.sequencer);
phase.drop_objection(this);
endtask: run_phase
module hdl_top;
logic clk;
logic reset;
wire[2:0] req;
wire[2:0] grant;
sfr_master_bfm SFR_MASTER(.clk(clk),
.reset(reset),
.req(req),
.grant(grant)
sfr_monitor_bfm SFR_MONITOR(.clk(clk),
.reset(reset),
.req (req),
.grant (grant));
round_robin_arbiter dut (.clk(clk),
.rst(reset),
.req(req),
.grant(grant)
reset <= 1;
clk <= 0;
repeat(10) begin
#10ns clk <= ~clk;
reset <= 0;
#10ns clk <= ~clk;
// initial begin
$dumpfile ("dump.vcd");
$dumpvars (0,hdl_top);
// end
#500 $finish;
uvm_config_db #(virtual sfr_master_bfm)::set(null, "uvm_test_top", "SFR_MASTER", SFR_MASTER);
uvm_config_db #(virtual sfr_monitor_bfm)::set(null, "uvm_test_top", "SFR_MONITOR", SFR_MONITOR);
