How to compare the data from the c model golden file stored in text format and the data from the monitor in the uvm scoreboard
In reply to vinayks:
Can’t answer your question without knowing the format of the data in the text file. And is there a one to one correspondence with each line of the text file and the data return by your monitor?
Hello Dave,
The text file stores the integer type of date and each line of the text having the values for different input/output variables separated by commas.
Example:
var1,var2,var3,…varn
- 20,30 ,40…50
- 88,99,77,…81
now my requirement is var1 in line 1 should be compared with monitor var1 ,and var2 with monitor var2 …and so on
