Build phase,connect phase,start of simuation phase and run phase
I am not able to understand why build phase execution order is top to downword , connect phase is bottom to up, start of simulation phase is bottom to up and run phase execution order is parallel
In reply to taufeeq_khan:
  1. build_phase() is top-down because a child component gets created in its parent’s build_phase().
  2. connect_phase() is bottom-up because it was easier than making it top-down. It really doesn’t matter.
  3. Same for start_of_simulation().
  4. run_phase() is a task, so it has to be parallel so that all components’ run_phase() methods will run concurrently.
In reply to tfitz:
Thanks for replying
please explane more about the start of simulation and run phase
Typical use for the different phases are described here.
You should also see this.
