If I have a block level monitor that writes the AP of the agent and the env connects the agent to the block level scoreboard, can I reuse the same monitor/agent at the top level for a top level scoreboard?
Essentially can one monitor/agent connect to two different scoreboards? Multiple subscribers to the same analysis port?
If so, how will the connection to the top level scoreboard look like?
For example :
At the agent level :
mon.analysis_port.connect(this.analysis_port);
At the env level : here sb is the “block” level scoreboard.
i_agt.analysis_port.connect(sb.before_export);
At the env level : sb_top is the “top” level scoreboard
i_agt.analysis_port.connect(sb_top.before_export);
Please point me to a usage case?
