Please find my code on the edaplayground here: Basic sequencer-driver connection - EDA Playground
In the top module, I am instantiating the dut and then am trying to bind an interface to the signals on it.
module tb_top;
dut dut1();
bind dut basic basic_intf(.clk(clk), .reset(reset), .addr(addr), .addr_out(addr_out));
run_test("base_test");
interface basic(
input clk,
input reset,
inout [7:0] addr,
inout [7:0] addr_out);
modport dut(
input clk,
input reset,
input addr,
output addr_out
endinterface
The error I am getting is:
Error-[VIHIOP] Variable in high conn of inout port
testbench.sv, 144
dut, “clk”
This variable is not a net, it cannot be connected to an inout port.
Source info: : basic basic_intf( .clk (clk), .reset (reset), .addr (addr),
.addr_out (addr_out));
If I declare these signals as wire I will not be able to use <= operator in the driving function. I want add that interface to config_db and retrieve it in the test. Test is a class of type uvm_test.
How do I resolve this?
