Hi All,
I just wanted to have some ideas on the better place for the uvm_components to get the interface through config_db below are the two ways.
Method I:
//call the uvm_config_db in respective uvm_component’s like driver,monitor’s “build_phase” as below
if (!uvm_config_db#(virtual SBus)::get(this, “”, “Sbus_if_h”, Sbus_if_h)) begin
`uvm_fatal(“repective_component”, “No virtual interface specified for this driver instance”)
Method II:
//call the uvm_config_db for all the uvm_component’s like driver,monitor to get the interface in the agents build_phase as below
//In the agents build_phase
driver drv;
monitor mon;
mon = monitor::type_id::create(“mon”, this);
drv = driver::type_id::create(“drv”, this);
//Driver gets the interface
if (!uvm_config_db#(virtual SBus)::get(this, “”, “Sbus_if_h”, drv.Sbus_if_h))
`uvm_fatal(get_type_name(), “DRIVER Could not get the SBUS interface for config”)
//Monitor gets the interface
if (!uvm_config_db#(virtual SBus)::get(this, “”, “Sbus_if_h”, mon.Sbus_if_h))
`uvm_fatal(get_type_name(), “MONITOR Could not get the SBUS interface for config”)
I feel method II is better as it makes each uvm_component independent of get interfaces and just by reading the agents file others can get the better observability rather than going to each components file for observing.
So,Your suggestions on this…
Thanks…
