I am verifying Bluetooth 5.0 and I would like to know the best method of writing layered sequences keeping controllability and reusability in mind.
FIRST APPROACH:
There is a virtual sequence which I haven’t shown here and the mid level_1 sequence is as follows:
class ble_set_adv_ext_parameters extends uvm_sequence;
task body();
set_conn_idx_seq.start(m_sequencer,this);
set_adv_param_seq.start(m_sequencer,this);
The mid level_2 sequence is as follows:
class ble_set_connection_index_sequence extends uvm_sequence;
task body();
ble_ahb_sing_wrt_seq = ble_ahb_single_write_sequence :: type_id :: create("ble_ahb_sing_wrt_seq");
ble_ahb_sing_wrt_seq.write(32'h0 , 16'h0,m_sequencer,this);
Then there is a bottom level sequence :
class ble_ahb_single_write_sequence extends uvm_sequence #(ble_ahb_sequence_item);
extern task body();
extern task write(input bit [31:0] haddr, input bit[15:0] hwdata,input uvm_sequencer_base seqr,input uvm_sequence_base parent = null);
task ble_ahb_single_write_sequence :: body();
start_item(ble_ahb_seq_item);
assert (ble_ahb_seq_item.randomize() with {
ble_ahb_seq_item.haddr == local :: haddr;
ble_ahb_seq_item.hwdata == local :: hwdata;
ble_ahb_seq_item.hwrite == 1;
ble_ahb_seq_item.hsel == 1;
ble_ahb_seq_item.hburst == 3'b000;
finish_item(ble_ahb_seq_item);
`uvm_info("AHB_Single_Write_Sequence", "Exiting Slave Sequence", UVM_LOW)
task ble_ahb_single_write_sequence :: write (input bit [31:0] haddr, input bit[15:0] hwdata,input uvm_sequencer_base seqr,input uvm_sequence_base parent = null);
this.haddr = haddr;
this.hwdata = hwdata;
this.start(seqr,parent);
SECOND APPROACH:
In this approach, the mid_level sequence is not sub-divided
task body();
ble_ahb_sing_wrt_seq.write(32'h5 , 16'h456,m_sequencer,this);
If I want to change the data written into the registers, and if I follow the first approach, I can override only the required mid_level_2 sequence without changing the mid_level_1 sequence. However if I use the second approach, If I want to change the written data, I have to use a new mid_level_1 sequence.
