Currently I’m trying to understand about standard transaction class.
Especially, Overriding the do_copy() and do_compare() methods with uvm_object inputs.
Here example for do_copy of spi_seq_item class.
class spi_seq_item extends uvm_sequence_item;
// UVM Factory Registration Macro
`uvm_object_utils(spi_seq_item)
// Data Members (Outputs rand, inputs non-rand)
rand logic[127:0] spi_data;
rand bit[6:0] no_bits;
rand bit RX_NEG;
// Analysis members:
logic[127:0] nedge_mosi;
logic[127:0] pedge_mosi;
logic[127:0] nedge_miso;
logic[127:0] pedge_miso;
logic[7:0] cs;
// Methods
// Standard UVM Methods:
extern function new(string name = "spi_seq_item");
extern function void do_copy(uvm_object rhs);
extern function bit do_compare(uvm_object rhs, uvm_comparer comparer);
extern function string convert2string();
extern function void do_print(uvm_printer printer);
extern function void do_record(uvm_recorder recorder);
endclass:spi_seq_item
function spi_seq_item::new(string name = "spi_seq_item");
function void spi_seq_item::do_copy(uvm_object rhs);
spi_seq_item rhs_;
if(!$cast(rhs_, rhs)) begin
`uvm_fatal("do_copy", "cast of rhs object failed")
super.do_copy(rhs);
// Copy over data members:
spi_data = rhs_.spi_data;
no_bits = rhs_.no_bits;
RX_NEG = rhs_.RX_NEG;
nedge_mosi = rhs_.nedge_mosi;
pedge_mosi = rhs_.pedge_mosi;
nedge_miso = rhs_.nedge_miso;
pedge_miso = rhs_.pedge_miso;
cs = rhs_.cs;
endfunction:do_copy
I have some question about do_methods().
Q1. In do_copy() function, $cast(rhs_, rhs) implemented with rhs_, rhs.
rhs_ is spi_seq_item object. and rhs is uvm_object object.
rhs has no spi_seq_item’s properties. so $cast() was used.
In rhs_.spi_data, this spi_data is declared in spi_seq_item as rand logic[127:0] spi_data;
But I’m confused that where “spi_data” is declared from “spi_data = rhs_.spi_data;”?
