Hello,
I am trying to write some value to through backdoor access to register cnt_reg in my vhdl design.
process (clk, reset, rw)
if reset = '1' then
cnt_reg <= (others => '0');
elsif clk'event and clk = '1' then
if(rw = '1') then
cnt_reg <= cnt_reg + '1';
end if;
end if;
end process;
I am introducing myself to UVM register layer so design is very simple, anyway when i try this in test:
m_env.m_agent.m_reg_block_p1.cntrl_reg.write(status, 'b101, UVM_BACKDOOR);
it writes 101 but in HEX notation, like 0001 0000 0001,
if i simply try to write
m_env.m_agent.m_reg_block_p1.cntrl_reg.write(status, 23, UVM_BACKDOOR);
i see 32’h0001 0111 (this is hex).
I cant figure it out why he take binary number and represent it in same way but in hex.
this is build phase of my agent :
m_driver = driver::type_id::create("m_driver",this);
m_sequencer = command_sequencer::type_id::create("m_sequencer", this);
m_monitor = monitor::type_id::create("m_monitor", this);
m_reg_adapter = reg_adapter::type_id::create("m_reg_adapter", this);
**m_reg_block_p1 = reg_block_p1::type_id::create("m_reg_block_p1", this);
m_reg_block_p1.configure(.hdl_path("top.dut"));
m_reg_block_p1.build();
m_reg_block_p1.cntrl_reg.clear_hdl_path();
m_reg_block_p1.cntrl_reg.add_hdl_path_slice( .name( "cnt_reg" ), .offset( 0 ), .size( 8 ) );
m_reg_block_p1.lock_model();**
endfunction : build_phase
This is register block:
class reg_block_p1 extends uvm_reg_block;
`uvm_object_utils(reg_block_p1)
rand reg_cntrl_rw cntrl_reg;
uvm_reg_map reg_map;
function new( string name = "reg_block_p1" );
super.new( .name( name ), .has_coverage( UVM_NO_COVERAGE ) );
endfunction: new
cntrl_reg = reg_cntrl_rw::type_id::create("cntrl_reg");
cntrl_reg.configure( .blk_parent( this ), .hdl_path("reg_mod") );
cntrl_reg.build();
reg_map = create_map(.name("reg_map"),
.base_addr(8'h00),
.n_bytes(1),
.endian(UVM_LITTLE_ENDIAN));
reg_map.add_reg(.rg(cntrl_reg),
.offset(8'h00),
.rights("RW"));
endfunction: build
I have one more question. I am not sure if my hdl paths are correct. For example what should i put as hdl path when i configure register? is this correct?
cntrl_reg.configure( .blk_parent( this ), .hdl_path(“reg_mod”) );
reg_mod is name of my vhdl entity.
But in top module i have this:
reg_mod dut( .data_in(dut_interface.data_in), .addr(dut_interface.addr),
.rw(dut_interface.rw), .clk(dut_interface.clk),
.reset(dut_interface.reset), .result(dut_interface.result));
endclass: reg_block_p1
