I have a register which can be accessed through indirect mechanism only.
Below is the example (copied from another forum)
// Real DUT register
// way field controls which data register
// will be ascessed
class ctrl_reg extends uvm_reg;
uvm_reg_field some_field;
uvm_reg_field way; // if 0, access to data0 reg, if 1, access to data1 reg
// Virtual register, idx field is a handle
// to way field of ctrl_reg
class idx_reg extends uvm_reg;
uvm_reg_field idx;
// data0 and data1 share the same physical
// address
class data0_reg extends uvm_reg;
uvm_reg_field field0;
class data1_reg extends uvm_reg;
uvm_reg_field field1;
// Indirect register for accesing data0 and
// data1 registers.
// The number of bits in each register in
// the register array must be equal to n_bits
// of this register.
class data_reg extends uvm_reg_indirect_data;
// No fields
class reg_model extends uvm_reg_block;
ctrl_reg ctrl;
idx_reg idx;
data0_reg data0;
data1_reg data1;
data_reg data;
uvm_reg reg_ar[];
virtual function build();
reg_ar = new[2];
data0 = data0_reg::type_id::create();
data0.configure(this);
data.build();
data1 = data1_reg::type_id::create();
data1.configure(this);
data.build();
reg_ar[0] = data0;
reg_ar[1] = data1;
ctrl = ctrl_reg::type_id::create();
ctrl.configure(this);
ctrl.build();
idx = idx_reg::type_id::create();
idx.configure(this);
idx.build();
idx.idx = ctrl.way;
data = data_reg::type_id::create();
data.configure(idx, reg_ar, this, null);
data.build();
default_map = create_map(““, 0, 4, UVM_BIG_ENDIAN);
default_map.add_reg(ctrl, 0);
default_map.add_reg(data, 4);
According to the userguide "The registers in the indirect register array cannot be accessed via a back-door access to the “data” register.
Back-door access to the register array is provided by performing back-door accesses via the unmapped,indirect register itself."
In that case,how should I access data0 and data1 backdoor.
