hi guys,
when i using Backdoor to write register and found that could not writing succeed. please help me guys, thanks. posted code below.
frontdoor read/write could be success, so used to check backdoor’s operation results.
class gpio_cfg_reg_seq extends uvm_reg_sequence;
`uvm_object_utils(gpio_cfg_reg_seq)
gpio_regfile reg_model;
function new(string name=“gpio_cfg_reg_seq”);
endfunction : new
//`uvm_declare_p_sequencer(gpio_sequencer)
rand bit [31:0] data;
bit [31:0] rdata;
rand int gpio_inst;
string gpio_rf;
virtual task body();
uvm_status_e status;
uvm_reg_data_t data;
**reg_model.direction_mode.write(status, 32'h5678, UVM_BACKDOOR, .parent(this));**
**reg_model.direction_mode.read(status, data, UVM_FRONTDOOR, .parent(this));**
endclass : gpio_cfg_reg_seq
class case_base extends uvm_test;
subsystem_config o_cfg;
subsystem_virtual_sequencer v_seqr;
subsystem_env o_env;
apb_ss_reg_model_c reg_model_ss; // Register Model
reg_to_ahb_adapter reg2ahb; // Adapter Object - REG to APB
uvm_reg_predictor#(ahb_transfer) ahb_predictor; //Predictor - APB to REG
uvm_component_utils_begin(case_base)
uvm_field_object(reg_model, UVM_DEFAULT | UVM_REFERENCE)
uvm_field_object(reg2ahb, UVM_DEFAULT | UVM_REFERENCE)
uvm_component_utils_end
//function new(string name, uvm_component parent=null);
super.new(name,parent);
o_env = subsystem_env::type_id::create(“o_env”,this);
o_cfg = subsystem_config::type_id::create(“o_cfg”,this);
v_seqr = subsystem_virtual_sequencer::type_id::create(“v_seqr”,this);
ahb_predictor = uvm_reg_predictor#(ahb_transfer)::type_id::create("ahb_predictor", this);
reg2ahb = reg_to_ahb_adapter::type_id::create("reg2ahb");
reg_model_ss = apb_ss_reg_model_c::type_id::create("reg_model_ss",this);
reg_model = gpio_regfile::type_id::create("reg_model",this);
uvm_reg::include_coverage("*", UVM_CVR_ALL);
reg_model.configure(null,"");
reg_model.build();
reg_model.lock_model();
reg_model.reset();
**reg_model.set_hdl_path_root("subsystem_top.i_apb_subsystem.i_gpio_veneer.i_gpio_lite.i_gpio_lite_subunit");**
uvm_config_db#(gpio_config)::set(null, "uvm_test_top.o_env.gpio0", "gpio_cfg", o_cfg.gpio_cfg);
uvm_config_db#(ahb_config)::set(null, "uvm_test_top.o_env.ahb0", "ahb_cfg", o_cfg.ahb_cfg); //to be finish
if( reg_model != null) begin
uvm_config_db#(gpio_regfile)::set(this, "v_seqr.subsystem_virtual_sequence.gpio_cfg_seq", "reg_model", reg_model);
endfunction : build_phase
super.connect_phase(phase);
//v_seqr.o_gpio_seqr = o_env.gpio0.g_agent.g_sequencer;
v_seqr.o_ahb_seqr = o_env.ahb0.master_agent.sequencer;
//reg_model.default_map.set_sequencer(o_env.ahb0.master_agent.sequencer, reg2ahb);
//reg_model.default_map.set_sequencer(o_env.gpio0.g_agent.g_sequencer, reg2ahb);
reg_model.default_map.set_sequencer(v_seqr.o_ahb_seqr , reg2ahb);
reg_model.default_map.set_auto_predict(1);
//if (o_env.gpio0.g_agent.is_active == UVM_ACTIVE)
// v_seqr.o_gpio_seqr = o_env.gpio0.g_agent.g_sequencer;
virtual function void end_of_elaboration_phase(uvm_phase phase);
super.end_of_elaboration_phase(phase);
//if(uvm_print_enabled == (UVM_HIGH))
o_cfg.print();
super.run_phase(phase);
class gpio_regfile extends uvm_reg_block;
rand bypass_mode_c bypass_mode;
rand direction_mode_c direction_mode;
rand output_enable_c output_enable;
rand output_value_c output_value;
rand input_value_c input_value;
// Now create all registers
bypass_mode = bypass_mode_c::type_id::create(“bypass_mode”, , get_full_name());
direction_mode = direction_mode_c::type_id::create(“direction_mode”, , get_full_name());
output_enable = output_enable_c::type_id::create(“output_enable”, , get_full_name());
output_value = output_value_c::type_id::create(“output_value”, , get_full_name());
input_value = input_value_c::type_id::create(“input_value”, , get_full_name());
// Now build the registers. Set parent and hdl_paths
bypass_mode.configure(this, null, “bypass_mode”);
bypass_mode.build();
direction_mode.configure(this, null, “direction_mode”);
direction_mode.build();
output_enable.configure(this, null, “output_enable”);
output_enable.build();
output_value.configure(this, null, “output_value”);
output_value.build();
input_value.configure(this, null, “input_value”);
input_value.build();
// Now define address mappings
default_map = create_map(“default_map”, 0, 4, UVM_LITTLE_ENDIAN);
default_map.add_reg(bypass_mode, UVM_REG_ADDR_WIDTH'h00820000, "RW"); default_map.add_reg(direction_mode,
UVM_REG_ADDR_WIDTH’h00820004, “RW”);
default_map.add_reg(output_enable, UVM_REG_ADDR_WIDTH'h00820008, "RW"); default_map.add_reg(output_value,
UVM_REG_ADDR_WIDTH’h0082000c, “RW”);
default_map.add_reg(input_value, `UVM_REG_ADDR_WIDTH’h00820010, “RO”);
`uvm_object_utils(gpio_regfile)
function new(input string name=“unnamed-gpio_rf”);
super.new(name, UVM_NO_COVERAGE);
endfunction : new
endclass : gpio_regfile
