Back jump from run_phse to Build phase
Hi All,
I have a requirement to back jump from run_phase to build phase ?
Is there any way how can I do this implementation ?
In reply to kuldeep sharma:
Could you please explain how this requirement looks lik?
There is no way to do this. But under certain circumstances you might split your sequence in smaller parts. Then you can reconfigure your environment and run these sequences.
Hi ,
Thanks for the reply.
My requirement is after complete transfer , i want to put HARD Reset , and run simulation with same descriptor. Right now i am preloading my descriptor from build_phase.
Hi sharma,
I don’t know why your simualation has to jump to build phase, not reset phase.
For reset test, the below code snippet may help you.
 virtual function void phase_ready_to_end(uvm_phase phase);
 super.phase_ready_to_end(phase);
 if(phase.get_imp() == uvm_shutdown_phase::get()) begin
 if(run_count == 0) begin
 phase.jump(uvm_pre_reset_phase::get());
 run_count++;
 endfunction : phase_ready_to_end
You can refer to the link here for more infomation: http://www.sunburst-design.com/papers/HunterSNUGSV_UVM_Resets_paper.pdf
Hi ,
You can initiate a hard reset from a sequence, because it will be asserted in the driver.
What do you mean with ‘descriptor’?
In reply to hungtaowu:
Hi sharma,
run_count++;
It is recommended to use the run_phase and to avoid the sub_phases of the run_phase.
You can execute any rest from the run_phase you do not need to do this in the reset_phase.
Hi ,
You cannot jump back to the build_phase. And even if you could, it wouldn’t make much sense since you would be replicating your entire test bench architecture. There is no way to delete a component once it’s been constructed.
