Associative array handle copy, coherency issue
Hi VA,
Found an issue in my verification testbench.
Created an associative array in my env class in build_phase.
Array was initialized with 2048 items using the keys of the associative array.
    class custome_env extends uvm_env;
         custome_ref_model   ref_model;
         bit[512-1:0]        cache_image[int];
         function void build_cache_image();
             for (int unsigned ii=0; ii < 2048; ii++) begin
                cache_image[addr] = {16{ii}};
                addr += 64; //addr in byte resolution.
Later in connect_phase of my custome_env class linked this array to same array type and name in my ref_model class:
            ref_model.cache_image  = this.cache_image;
    class custome_ref_model extends uvm_component;
During the test run, the associative array was modified many times in the ref_model class.
Unfortunately found in the check_phase of the test that the associative array in ref_model class is different than the one defined in the custome_env class.
How is it possible?
Why the items of associative array in the custome_env class was not being modified during the test run?
Michael
In reply to Michael54:
The arrays are not linked by an assignment; the array assignment creates a copy.
You might want to look at the class uvm_pool which essentially wraps an associative array in a class object. Then you can share the object handles.
