Depending on other signals (not shown) you can have the following relationships between CSEL and ACK.
CSEL , ACK immediately asserts. Fine
CSEL , ACK will assert some cycles later.
Back to back transactions, all valid.
My main issue is identifying a “unique” antecedent. In scenario 2, how do I cause the first attempt to fire, but prevent the following 2 from occurring. Is there some way to “lock-out” the assertion until it completes? There is no pipelining on this bus.
csel |-> (ack==0)[*0:10] ##1 ack ; // not unique, fails scenario 2
$rose(csel) |-> (ack==0)[*0:10] ##1 ack ; // unique, but fails scenario 3 (only catches the 1st instance)
In the antecedent test for an entry gate, a module variable
If successful entry, lock that gate.
If pass or fail, release the gate
Below is an example that I had before. It uses the sequence-match-item and function call. Upon pass or fail, that action item is used.
module thruout2;// /ch10/10.27/thruout2.sv
bit clk, sof, eof;
bit busy_sof;
default clocking @(posedge clk); endclocking
function void setval4busy(bit d);
busy_sof=d;
// This is not catching multiple sof's and one eof within valid.
// It should check that for one sof, there should be only one eof.
ap_sof_eof: assert property
// Once antecedent fires, no other one will fire again
((sof && busy_sof==1'b0, setval4busy(1'b1)) |->
##[1:5] (eof)) setval4busy(1'b0); // reset flag if property is true
else setval4busy(1'b0); // reset flag if property is false
ap_neversof_when_busy: assert property(not(sof && busy_sof));
The solution above is more of a lockout of other assertions until the current one completes.
It uses a semaphore. If this is what you want, you may want to add another assertion that states that no other valid potential assertions occur during this lockout.
