Array of UVM Transactions
Hello, I want to implement an array of my transactions but I don’t know how to make it if I have 5 transactions for example. Can anyone give me an example of this issue?
In reply to Mohammed Essam Abd El Samee:
The question is for what do you need this array. Is it only to store? Then you could use a uv_tlm_fifo.
I want to use this array to run it and show it as a separate transaction contains many transaction objects which contain many data members.
You don’t need such an array. Run the generation of your tansaction objects in a loop. This gives you what you want.
I know this but, I want to know the mechanism of implementing an array of transactions.
class transaction extends uvm_sequence_item;
`uvm_object_utils(transaction)
endtransaction
transaction tr[];
tr = new[5];
foreach(tr[ii]) tr[ii] = transaction::type_id::create("tr");
