I want to define&create an array of parametric classes, each one with a specific parameter.
In the original code I have something like this:
package my_pack
parameter num_of_fpgas = 2; //defined in external package
import my_pack::*;
class my_agent#(int fpga_index) extends uvm_agent;
`uvm_components_param_utils(my_agent#(fpga_index))
class dut_env extends uvm_env;
my_agent#(0) fpga0_agent;
my_agent#(1) fpga1_agent;
fpga0_agent=my_agent#(0)::type_id::create("fpga0_agent",this);
fpga1_agent=my_agent#(1)::type_id::create("fpga1_agent",this);
I want to declare an unpacked array of my_agent(size of array = num_of_fpgas), in which each object will get the parameter of its index, i.e. sth like:
my_agent#(????) fpga_agent[0:num_of_fpgas -1]; //how to define it???
//fpga_agent[0] should get parameter fpga_index=0
//fpga_agent[1] should get parameter fpga_index=1, etc...
//How to define the build phase??
In reply to shaygueta:
It is better to save parameters for values requiring constant expressions like variable widths, or types. If fpga_index is just used for something like address decoding, make it a class member variable instead.
class my_agent extends uvm_agent;
`uvm_components_utils(my_agent)
int fpga_index;
my_agent fpga_agent[num_of_fpgas];
foreach(fpga_agent[index]) begin
fpga_agent[index] = my_agent::type_id::create($sformatf("fpga_agent_%0d",index),this);
fpga_agent[index].fpga_index = index;
If your situation requires fpga_index to be a parameter, then your array elements need to be declared with a common base class, like uvm_agent. However, you will not be able to make any connections your agent from a uvm_agent class. So what you can do is create a common base class.
class my_agent_base extends uvm_agent;
uvm_analysis_port#(my_transaction) ap;
class my_agent#(int fpga_index) extends my_agent_base;
my_agent_base fpga_agent[num_of_fpgas];
foreach(fpga_agent[index]) case(index) // doing this because you cannot parameterize with a variable
0: fpga_agent[index] = my_agent#(0)::type_id::create($sformatf("fpga_agent_%0d",index),this);
1: fpga_agent[index] = my_agent#(1)::type_id::create($sformatf("fpga_agent_%0d",index),this);
2: fpga_agent[index] = my_agent#(2)::type_id::create($sformatf("fpga_agent_%0d",index),this);
default: `uvm_error("build_phase","exceeded max anticipated fpgas")
endcase
Now will be able to access fpga_agent[I].ap to connect this agent up to a scoreboard.
