ace_master_interface mst_if[`no_of_masters](aclk,resetn);
for(int i=0;i<`no_of_masters;i++)begin
uvm_config_db #(virtual ace_master_interface)::set(null,"*",$sformatf("mst_if[%0d]",i),mst_if[i]);
Error-[IIXMR] Invalid index in cross-module reference
../hdl/ace_top.sv, 141
Invalid index in cross-module reference due to index is not constant.
Argument: mst_if
Source info: : uvm_config_db::set(null, "*", $sformatf("mst_if[%0d]", i),
mst_if[i]);
Instance stack trace:
I’m gettin this error. Please help.
In reply to Raja VA:
You have to use a generate like this:
for(genvar i=0;i<`no_of_masters;i++)begin
initial
Arrays of instances are not true arrays of identically typed data elements and have to be handled specially at elaboration, not dynamically during simulation. Features like parameter overrides and port coercion can potentially make each instance element have different types and structures. The index into a true array is simply a computed offset into memory selecting a uniformly shaped element.
SystemVerilog treats the index of an array of instances (or generate for-loop of instances as part of the scope name. So mst_if[0], mst_if[i], … might as well be mst_if_zero, mst_if_one,…
genvar idx;
for(idx = 0; idx < num_inst; idx++) begin
initial begin : vif_inst
vif m_vif;
uvm_config_db #(vif)::set(null,"*",{PRE_FIX,$sformatf("vif[%0d]",idx)},m_vif);
//some code...
//use vif 0
vif_inst[0].m_vif.xyz = 0;
//use fix value or <font size=20>genvar</font> if set for all
