Hi everyone I have a syntax error in the following code where I want to connect component A to component B.The packets from component A would transacted to component B and then it would broadcast to three subscriber sub1,sub2,sub3.Any suggestion would be wisely appreciated.
//================ code starts here ===================//
`include "uvm_macros.svh"
// This is a transaction class in TLM, whose object will float around the env
class simple_packet extends uvm_object;
rand bit [7:0] addr;
rand bit [7:0] data;
bit rwb;
`uvm_object_utils_begin (simple_packet)
`uvm_field_int (addr, UVM_ALL_ON)
`uvm_field_int (data, UVM_ALL_ON)
`uvm_field_int (rwb, UVM_ALL_ON)
`uvm_object_utils_end
constraint c_addr { addr > 8'h2a; }
constraint c_data { data inside {[8'h14:8'he9]}; }
//=============== component A ===============//
class componentA extends uvm_component;
`uvm_component_utils (componentA)
// We are creating a put_port which will accept a "simple_packet" type of data
uvm_blocking_put_port #(simple_packet) put_port;
simple_packet pkt;
function new (string name = "componentA", uvm_component parent= null);
super.new (name, parent);
super.build_phase (phase);
// Remember that put_port is a class object and it will have to be
// created with new ()
put_port = new ("put_port", this);
virtual task run_phase (uvm_phase phase);
// Let us generate 5 packets and send it via the put_port
repeat (5) begin
pkt = simple_packet::type_id::create ("pkt");
assert(pkt.randomize ());
`uvm_info ("COMPA", "Packet sent to CompB", UVM_LOW)
pkt.print (uvm_default_line_printer);
put_port.put (pkt);
//=============== component B ==================//
class componentB extends uvm_component;
`uvm_component_utils (componentB)
// Mention type of transaction, and type of class that implements the put ()
uvm_blocking_put_imp #(simple_packet, componentB) put_export;
uvm_analysis_port #(simple_packet) ap;
function new (string name = "componentB", uvm_component parent = null);
put_export = new ("put_export", this);
ap = new ("analysis_port", this);
task put (simple_packet pkt);
// Here, we have received the packet from componentA
`uvm_info ("COMPB", "Packet received from CompA", UVM_LOW)
pkt.print ();
// Now pass it to other components via the analysis port
ap.write (pkt);
//================== sub ====================//
class sub #(type T = simple_packet) extends uvm_subscriber #(T);
`uvm_component_utils (sub)
function new (string name = "sub", uvm_component parent = null);
// Note that the class object name has to be "t" - anything else will result
// in compilation error
virtual function void write (T t);
`uvm_info (get_full_name(), "Sub got transaction", UVM_MEDIUM)
//=========== environment ================//
class my_env extends uvm_env;
`uvm_component_utils (my_env)
componentA compA;
componentB compB;
sub sub1;
sub sub2;
sub sub3;
function new (string name = "my_env", uvm_component parent = null);
// Create an object of both components
compA = componentA::type_id::create ("compA", this);
compB = componentB::type_id::create ("compB", this);
sub1 = sub#(simple_packet)::type_id::create ("sub1", this);
sub2 = sub#(simple_packet)::type_id::create ("sub2", this);
sub3 = sub#(simple_packet)::type_id::create ("sub3", this);
virtual function void connect_phase (uvm_phase phase);
compA.put_port.connect (compB.put_export);
// Connect Analysis Ports
compB.ap.connect (sub1.analysis_export);
compB.ap.connect (sub2.analysis_export);
compB.ap.connect (sub3.analysis_export);
//============== base_test ==============//
`uvm_component_utils (base_test)
my_env m_top_env;
function new (string name, uvm_component parent = null);
endfunction : new
m_top_env = my_env::type_id::create ("m_top_env", this);
endfunction : build_phase
virtual function void end_of_elaboration_phase (uvm_phase phase);
// By now, the environment is all set up, just print the topology for debug
uvm_top.print_topology ();
`timescale 1ns/1ps
//=========== top level test ============//
module tb_top;
run_test ("base_test");
//======================= END =========================//
