The link contains a code I started to write for a sequence detector, but I’m not able to figure out how to deal with the errors.
Thank You
Thank You
In reply to Lucifer_morn:
The problem was happened because the file “seq_agent.sv” was compiled multiple times.
To avoid it, please use as following macro:
`ifndef _SEQ_AGENT__SV_
`define _SEQ_AGENT__SV_
class seq_agent extends uvm_agent;
`endif
In reply to chris90:
That is not the correct way to prevent this error. The correct way is to use SV Packages.
package agent_pkg;
`include "uvm_macros.svh"
`include "seq_item.sv"
`include "seq_driver.sv"
`include "seq_monitor.sv"
`include "seq_agent.sv"
endpackage
Then you should import agent_pkg where required.
See this article for more information.
Update your package with the files mentioned
package seq_pkg;
include “seq_item.sv”
include "seq_sequence.sv"
include “seq_driver.sv”
include "seq_sequencer.sv"
include “seq_monitor.sv”
include “seq_env.sv”
`include “seq_top.sv”
endpackage
Find the error free code - > UVM sequence detector(1) - EDA Playground
