In the uvm_reg method
add_hdl_path_slice(string name,
int offset,
int size,
bit first = 0,
string kind = "RTL")
is the string name the name of the register field or is it the name of the RTL counterpart?
For example, say I have a 32 bit register X with a_x,b_x,c_x fields that occupy certain bits of the register. [ X[3] = a_x, X[5] = b_x, X[31] = c_x] These fields have corresponding flops (a,b,c) on the rtl and the other bits are unused. How is the hdl path added for such a case?
//In X reg file build function
a_x.configure(this, 1, 3);
b_x.configure(this, 1, 5);
c_x.configure(this, 1, 31);
add_hdl_path_slice("", 3, 1); //for a_x would the string name be a_x or a?
In reply to Vaishnavi Balasubramanian:
Hello, the string name is the path up to the register instance in the RTL something like:
uut.i1.i2.i3.register
In your case that path to the field doesn’t exist in the RTL meaning sometimes RTL uses DEFINES to make it clearer what bit of a specific field is deployed. Names provided in the RAL model are just result of the register description used.
the path will be:
add_hdl_path_slice("uut.i1.i2.i3.4.regsiter_name", 3, 1); //for a_x would the string name be a_x or a?
in case you wanna ad a bit specific path you would need to use:
$sformatf("uut.i1.i2.i3.4.regsiter_name[%0d]",bit_sel)
// or a define
`define reg_a_bit_sel(sel) $sformatf("uut.i1.i2.i3.4.regsiter_name[%0d]",``sel``)
Regards
