To add the clock delay in sequence using existing interface clock signal present in the interface
I want to add a two clock delay in the sequence using the existing clock signal present in the interface. My sequencer,driver,env are not visible. How to add the delay?
In reply to suvendra kumar sahoo:
There are a few things you can do with the sequence_item that you send to the driver
  • You can add a field to the transaction representing a delay for each item. Then your driver delays each transaction by the number of cycles
  • If your transaction is already command based (i.e. read, write, …) you can add another command that represents a cycle delay.
  • And, if you do not want or cannot change the sequence/driver, you can add another sequence/driver combination that is just there to count clock cycles. Many people also create a clock/reset interface solely for generating/waiting on clocks, and driving reset.
