Is adapter required for uvm_memory model or we can access the memory rthrough frontdoor or backdoor methods without an adapter?
I have built an uvm_mem class and reg_model for ,mapping but I am little bit confused whether I need a adapter for mem_model or is there any particular concept for memory model?
Thanks in advance
In reply to harshareddy132:
Yes, you still need an adapter. The key difference is there is no mirror for get/set access to conserve resources.
Thanks Dave, I also wanted to ask i have two address in my Mem model how to pass the second address to the adapter to read or write.
thanks in advance
You need to use the extension field in umm_reg_item. Here’s an example.
