in adapter class, reg2bus method is having only one argument, while bus2reg method is having 2 arguments. why??
In reply to rhariprasad:
For understanding this you need to know how these two methods are used in RAL.
Reg2bus method is used whenever a RAL transaction (read/write) is issued by your env or test, reg2bus will get uvm_reg_bus_op structure and form an bus transactions based on data provided in the op struct. The reg2bus return the bus sequence item that can be axi/ahb or any other type. The final transaction is sent on the bus_sequencer instance you had provided while initializing RAL.
Bus2Reg method translates transaction from sequence item type to uvm_reg_bus_op type which are passed as arguments to the function.
See the example code in uvm_reg_adapter for better understanding:
//| virtual function uvm_sequence_item reg2bus(uvm_reg_bus_op rw);
//| apb_item apb = apb_item::type_id::create("apb_item");
//| apb.op = (rw.kind == UVM_READ) ? apb::READ : apb::WRITE;
//| apb.addr = rw.addr;
//| apb.data = rw.data;
//| return apb;
//| endfunction
//| virtual function void bus2reg(uvm_sequencer_item bus_item,
//| uvm_reg_bus_op rw);
//| apb_item apb;
//| if (!$cast(apb,bus_item)) begin
//| `uvm_fatal("CONVERT_APB2REG","Bus item is not of type apb_item")
//| end
//| rw.kind = apb.op==apb::READ ? UVM_READ : UVM_WRITE;
//| rw.addr = apb.addr;
//| rw.data = apb.data;
//| rw.status = UVM_IS_OK;
//| endfunction
Hope this helps.
Rohit
We need to create sequence_item to send it to the driver. reg2bus() does that,
function uvm_sequence_item reg2bus(const ref uvm_reg_bus_op rw);
reg2bus() takes reference argument of type uvm_reg_bus_op and creates a sequence_item. So, here no need of 2nd argument.
Whereas bus2reg() needs two arguments,
function void bus2reg(uvm_sequence_item bus_item,
- Where first argument is sequence item to convert and second argument is reference to uvm_reg_bus_op type available in parent class. So, here we update register by reference.
- For bus2reg() there’s no return type of uvm_reg_bus_op because uvm_reg_bus_op is a Structure and not Class. So, creation and return statement cannot be used there.
