Hi ,
I have 4 Sub-Components with put ports . These 4 Child ports are connected to a single Parent port and the parent port is connected to an Imp.
From the parent component I want depending on some logic Only 1 Sub-port should communicate with the Imp at a time till select line changes ( Logic for selecting port )
Here is my code ::
class componentA extends uvm_component;
`uvm_component_utils(componentA)
uvm_blocking_put_port #(string) m_put_port;
function new (string name = "componentA", uvm_component parent= null);
super.new (name, parent);
m_put_port = new("m_put_port", this );
virtual task run_phase (uvm_phase phase);
int unsigned Index ;
phase.raise_objection(this);
for ( int i = 1 ; i < 3 ; i++ ) // Call put() Twice !!
m_put_port.put( get_name() ); // Only m_put_port.get_name() would return same instance name !!
# 3 ;
`uvm_info (get_name, $sformatf(" All put Done "), UVM_LOW)
phase.drop_objection(this);
class componentB extends uvm_component;
`uvm_component_utils (componentB)
uvm_blocking_put_imp #( string ,componentB) m_put_imp;
function new (string name = "componentB", uvm_component parent= null);
endfunctionclass componentA extends uvm_component;
# 3 ;
m_put_imp = new("m_put_imp", this);
task put ( string INT ) ;
`uvm_info ("CompB", $sformatf(" Called from %0s ",INT), UVM_LOW)
class agent extends uvm_agent ;
`uvm_component_utils(agent)
componentA compA[] ;
componentB compB ;
uvm_blocking_put_port #(string) p_put_port;
function new (string name = "agent", uvm_component parent= null);
compA = new[4] ;
for ( int i = 0 ; i < 4 ; i ++ )
compA[i] = componentA::type_id::create ($sformatf("compA_%0d",i), this);
compB = componentB::type_id::create ($sformatf("compB"), this);
p_put_port = new( "p_put_port" , this );
virtual function void connect_phase (uvm_phase phase);
for ( int i = 0 ; i < 4 ; i++ )
compA[i].m_put_port.connect(p_put_port);
p_put_port.connect(compB.m_put_imp);
task run_phase ( uvm_phase phase ) ;
// Need Logic here ??
// Inside a module
agent ag ;
ag = new("ag",null);
run_test();
Currently if I run this all 4 ports communicate with the Imp .
I want that even if I call put() from all 4 ports at same time , control shouldn’t transfer to the Imp for 3 of them .
Ex: At time 0 if select line is 0 ( Logic needed ) , only put() from CompA[0] should call the put() method in Imp whereas put() called from other ports shouldn’t call Imp ( Since Select line is 0 , Input 0 should be transferred to Output )
