What’s the best way to access API (tasks and functions) in a 3rd party model (e.g. processor model) buried in RTL? I’m getting an error in DVT when I try to do this in my driver:
top.dut.cpu.read_data(0);
Of course, my driver is inside of a package so I’m not supposed to be able to do this even though RivieraPRO allows it. What’s the best way to handle this? Somehow with an interface?
I read through the link that you pointed out and carefully read “The Missing Link: The Testbench to DUT Connection”, but I’m still having trouble. The following code below works but I need to have an interface for each dut in the testbench, so the hierarchy in “dut_intf” will need to be different. I’m thinking about how I can use “bind” to make this work but I still don’t think I’ll have access to the tasks in “mydesign_top”. How can I make this work without repeating the implementation of “abs_intf” for each internal module? In the real design, there are a lot of tasks that I will need access to and they are deep in the dut hierarchy.
package abs_pkg;
virtual class abs_intf;
bit y0, y1;
pure virtual task write (input bit i0, i1);
pure virtual task read;
endpackage
interface dut_intf;
import abs_pkg::*;
class probe_concrete extends abs_intf;
tb_top.dut0.write(i0, i1);
task read;
tb_top.dut0.read(y0, y1);
probe_concrete p = new;
endinterface
package uvmlike_pkg;
import abs_pkg::*;
class driver;
abs_intf vintf;
task run;
endpackage
module mysub( input bit i, output reg x);
initial x=0;
always @(i) x = i;
module mydesign_top;
bit it0, it1;
wire x0, x1;
mysub m0 (.i(it0), .x(x0));
mysub m1 (.i(it1), .x(x1));
#1;
it0 = i0;
it1 = i1;
#1;
task read (output bit out0, out1);
#1;
out0 = x0;
out1 = x1;
module tb_top;
import uvmlike_pkg::*;
bit out0, out1;
mydesign_top dut0 ();
mydesign_top dut1 ();
dut_intf intf();
driver d;
d = new;
d.vintf = intf.p;
dut0.read(out0, out1);
$display(" out : %b %b", out0, out1);
