# Will always\_comb block trigger if the signal value changes from 0/1 to X
**URL:** <https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741>\
**Category:** SystemVerilog\
**Tags:** always\_comb, force-release, System-Verilog, SystemVerilog\
**Created:** [June 1, 2023, 4:20pm UTC](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741 "2023-06-01T16:20:46Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![sj1992](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/ecae2f/32.png) [@sj1992](https://verificationacademy.com/forums/u/sj1992)\
**Post date:** [June 1, 2023, 4:20pm UTC](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/1 "2023-06-01T16:20:46Z")
</div>
Will always\_comb block trigger if the signal value changes from 0 or 1 to X ?
I am trying to force a signal to 0 if it changes to X. Below is my code. Will this work?
```verilog
logic [2:0] signal;
always_comb begin
   if(signal === 3'bxxx) begin
     force signal = 3'b000;
     release signal;
TIA
**Post date:** [June 1, 2023, 4:58pm UTC](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/2 "2023-06-01T16:58:05Z")
</div>
_In reply to [sj1992](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741):_
```verilog
module try_me;
  logic signal = 1;
  always_comb if (signal === 'x) $display("signal is x at %0d", $realtime);
  initial #2 signal = 'x;
**Post date:** [June 1, 2023, 5:53pm UTC](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/3 "2023-06-01T17:53:30Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/2):_
Thanks Dave. I do see that the always\_comb block gets triggered if the signal changes from 0/1 to X. But my force and release commands dont seem to be working. Should there be some time delay between force and release?
**Post date:** [June 1, 2023, 6:10pm UTC](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/4 "2023-06-01T18:10:45Z")
</div>
_In reply to [sj1992](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/3):_
That is a completely different question. The code you show works. You don’t even need a force/release statement. A simple procedural assignment to 0 would work. There must be something different in your environment than what you have shown.
**Post date:** [June 1, 2023, 6:35pm UTC](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/5 "2023-06-01T18:35:38Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/4):_
The Signal is inside the DUT RTL and is getting assigned in an always block. But when this signal gets assigned the value X in RTL I want to make it to 0. So I am trying to use force and release in my testbench so that the signal never becomes X. But this force and release dont seem to work.
**Post date:** [June 1, 2023, 6:48pm UTC](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/6 "2023-06-01T18:48:04Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/5):_
> _In reply to [sj1992](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/5):_
I tried the below code but the signal remains X after the force and release statements
```verilog
  logic [2:0] signal = 1;
  logic clk = 0;
  always_comb begin
     if (signal === 3'bxxx) begin
        force signal = 0;
        release signal;
        $display("after release signal is: %0b at %0d", signal,$realtime);
     #2 signal = 'x;
     #10 $display("calling finish");
     $stop();
     clk = 0;
     forever begin
        #1 clk = ~clk;
**Post date:** [June 1, 2023, 10:30pm UTC](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/7 "2023-06-01T22:30:30Z")
</div>
_In reply to [sj1992](https://verificationacademy.com/forums/t/will-always-comb-block-trigger-if-the-signal-value-changes-from-0-1-to-x/41741/6):_
OK, my mistake (but a complete reproducible example would have helped me realize that sooner). The code you originally wrote will not work because a variable that is both read and written to in an alays\_comb block is not part of its sensitivity. If you replace the **always\_comb** with **always @signal** you get your desired results.
I think this is an mistake in the LRM because a force statement is not supposed to be considered as a procedural or continuous assignment for the other rules that disallow multiple drivers. It should not be considered an assignment for the sensitivity rules as well. But probably too late to change.
