# Why doesnt UVM\_VERBOSITY from command line work on object extended from uvm\_report\_object
**URL:** <https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884>\
**Category:** UVM\
**Tags:** uvm\_report\_object, UVM, verbosity\
**Created:** [March 23, 2021, 6:09pm UTC](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884 "2021-03-23T18:09:59Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![justrajdeep](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/j/cab0a1/32.png) [@justrajdeep](https://verificationacademy.com/forums/u/justrajdeep)\
**Post date:** [March 23, 2021, 6:09pm UTC](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884/1 "2021-03-23T18:09:59Z")
</div>
I have an object env\_cfg which is extended from uvm\_report\_object.
I always get the uvm messages with UVM\_MEDIUM. The run-time options have +UVM\_VERBOSITY=UVM\_NONE.
If I extend env\_cfg from uvm\_object then i dont see this issue.
[Eda playground example](https://www.edaplayground.com/x/Ddev)
In the example above you can see that the line
> “this should not be printed”
is with
```auto
UVM_MEDIUM
and i have
```auto
+UVM_VERBOSITY=UVM_NONE
I expected it to be not printed, but it gets printed. Is this a bug?
**Author:** ![rag123](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/r/eada6e/32.png) [@rag123](https://verificationacademy.com/forums/u/rag123)\
**Post date:** [March 24, 2021, 3:18am UTC](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884/2 "2021-03-24T03:18:55Z")
</div>
_In reply to [justrajdeep](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884):_
The uvm\_report\_object uses set\_report\_macros which means we have to set the verbosity through set\_report\_verbosity\_level.
check the updated example here.
> **[EDA Playground](https://www.edaplayground.com/x/Qkj2)**
> Edit, save, simulate, synthesize SystemVerilog, Verilog, VHDL and other HDLs from your web browser.
**Post date:** [March 24, 2021, 3:30am UTC](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884/3 "2021-03-24T03:30:16Z")
</div>
_In reply to [rag123](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884/2):_
> _In reply to [justrajdeep](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884/2):_
> [UVM: The start and the end of each phase(3) - EDA Playground](https://www.edaplayground.com/x/Qkj2)
I understand that i can use the
set\_report\_\* methods, but then i cannot change the verbosity level at runtime from command line, i will have to compile each time.
This looks like a limitation.
**Post date:** [March 24, 2021, 7:21am UTC](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884/4 "2021-03-24T07:21:24Z")
</div>
_In reply to [justrajdeep](https://verificationacademy.com/forums/t/why-doesnt-uvm-verbosity-from-command-line-work-on-object-extended-from-uvm-report-object/38884/3):_
+UVM\_VERBOSITY only works on classes derived from uvm\_component. It also works on classes not derived from uvm\_report\_object because their reporting methods use the global reporting object from uvm\_test\_top. This does leave classes derived directly from uvm\_report\_object out of scope for the command line options.
Since you are using env\_cfg as the message ID, you can derive env\_cfg from uvm\_object and use
```auto
+uvm_set_verbosity=*,env_cfg,UVM_NONE,build
