# What is unnamed uvm\_root type?
**URL:** <https://verificationacademy.com/forums/t/what-is-unnamed-uvm-root-type/40082>\
**Category:** UVM\
**Tags:** systemverilog-uvm, UVM\
**Created:** [February 21, 2022, 9:48am UTC](https://verificationacademy.com/forums/t/what-is-unnamed-uvm-root-type/40082 "2022-02-21T09:48:53Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![UVM\_LOVE](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/uvm_love/32/1684_2.png) [@UVM\_LOVE](https://verificationacademy.com/forums/u/UVM_LOVE)\
**Post date:** [February 21, 2022, 9:48am UTC](https://verificationacademy.com/forums/t/what-is-unnamed-uvm-root-type/40082/1 "2022-02-21T09:48:53Z")
</div>
Hi.
I got the uvm\_root type when I try to print my test case as bewow.
I didn’t get it this situaltion, what am I suppoed to do to resolve unnamed problem?
If I want to connect between some sequence and my sequencer, then how am I suppoed to do ?
Can I just ignore about " uvm\_root " ? to connect?
I used printing way as below.
```verilog
  virtual function void end_of_elaboration_phase(uvm_phase phase);
        uvm_root uvm_top = uvm_root::get();
        super.end_of_elaboration_phase(phase);
        `uvm_info(get_type_name(), $sformatf("Printing environment settings: \n %0s", uvm_top.sprint()), UVM_LOW)
```verilog
UVM_INFO plain_simple_write_test.sv(49) @ 0: uvm_test_top [plain_simple_write_test] Printing environment settings:
Name Type Size Value
<unnamed> uvm_root - @1040
  uvm_test_top plain_simple_write_test - @2881
    plain_environment plain_environment_c - @2971
      plain_agent plain_agent_c - @3644
        sequencer plain_sequencer - @3676
          rsp_export uvm_analysis_export - @3733
          seq_item_export uvm_seq_item_pull_imp - @4283
          arbitration_queue array 0 -
          lock_queue array 0 -
          num_last_reqs integral 32 'd1
          num_last_rsps integral 32 'd1
        vijay_driver plain_driver - @4314
          rsp_port uvm_analysis_port - @4413
          seq_item_port uvm_seq_item_pull_port - @4364
      virtual_sequencer plain_virtual_sequencer - @3002
        rsp_export uvm_analysis_export - @3060
        seq_item_export uvm_seq_item_pull_imp - @3610
**Post date:** [February 21, 2022, 10:46pm UTC](https://verificationacademy.com/forums/t/what-is-unnamed-uvm-root-type/40082/2 "2022-02-21T22:46:44Z")
</div>
_In reply to [UVM\_LOVE](https://verificationacademy.com/forums/t/what-is-unnamed-uvm-root-type/40082):_
Why is this a problem? You should just ignore uvm\_root and consider your test as the top level named component.
