# Variable declared inside a static function
**URL:** <https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog\
**Created:** [September 7, 2018, 12:13pm UTC](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005 "2018-09-07T12:13:33Z")\
**Showing post:** 2
**Post date:** [September 7, 2018, 3:04pm UTC](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005/2 "2018-09-07T15:04:29Z")
_In reply to [Manoj J](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005):_
‘a’ is an automatic variable that gets initialized to 0 on each call to get(). You can declare ‘a’ as a static variable if thst is what you want.
The syntax
static function static was made illegal in the 1800-2009 LRM to prevent the confusion you are having now.
See [automatic variables inside static method | Verification Academy](https://verificationacademy.com/forums/systemverilog/automatic-variables-inside-static-method#reply-42858)
_[View the full topic](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005)._
