# Variable declared inside a static function
**URL:** <https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog\
**Created:** [September 7, 2018, 12:13pm UTC](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005 "2018-09-07T12:13:33Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![ManojJ](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/m/22d042/32.png) [@ManojJ](https://verificationacademy.com/forums/u/ManojJ)\
**Post date:** [September 7, 2018, 12:13pm UTC](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005/1 "2018-09-07T12:13:33Z")
</div>
Hi, this is the code i tried to execute,
```verilog
class base;
  static int i;
    static function get();
     int a;
      a++;
      $display(a);
    base b1,b2;
    b1.get();
    b1.get();
    b2.get();
the output was
1
1
1
why a is incrementing only once? and can we declare a non static variable inside a static function?
Can anyone please explain the operation of this code…
and if I declare the same function as
```verilog
 static function static get()
i am getting the output
1
2
3
**Post date:** [September 7, 2018, 3:04pm UTC](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005/2 "2018-09-07T15:04:29Z")
</div>
_In reply to [Manoj J](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005):_
‘a’ is an automatic variable that gets initialized to 0 on each call to get(). You can declare ‘a’ as a static variable if thst is what you want.
The syntax
static function static was made illegal in the 1800-2009 LRM to prevent the confusion you are having now.
See [automatic variables inside static method | Verification Academy](https://verificationacademy.com/forums/systemverilog/automatic-variables-inside-static-method#reply-42858)
**Post date:** [September 8, 2018, 4:53am UTC](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005/3 "2018-09-08T04:53:44Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/variable-declared-inside-a-static-function/35005/2):_
Thanks dave!!
