# Value of member class are not updated
**URL:** <https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, pass-argument-by-ref, systemverilog-Arrays\
**Created:** [December 15, 2016, 6:05am UTC](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652 "2016-12-15T06:05:23Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![saritr](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/df705f/32.png) [@saritr](https://verificationacademy.com/forums/u/saritr)\
**Post date:** [December 15, 2016, 6:05am UTC](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/1 "2016-12-15T06:05:23Z")
</div>
I have the following base class:
```verilog
class base_transaction extends uvm_sequence_item();
   int rand_int_list [$];
   bit rand_bit_list [$];
   bit [31:0] data [$];
   //uvm_object_utils\
   `uvm_object_utils(base_transaction)
   //constructor
   function new(string name = "base_transaction");
      super.new(name);
   endfunction: new
   //add to list functions
   function void add_rand_int(ref int mem);
      $display("array size is %d before push", rand_int_list.size());
      rand_int_list.push_back(mem);
      $display("array size is %d after push", rand_int_list.size());
      //rand_int_list[rand_int_list.size()] = mem;
   endfunction: add_rand_int
   function void add_rand_bit(ref bit mem);
     // rand_bit_list.
      rand_bit_list[rand_bit_list.size()] = mem;
   endfunction: add_rand_bit
   //function my_randomize
   function int my_randomize(int seed);
      int temp, success;
      if (rand_int_list.size > 0)
	   for (int i = 0; i < rand_int_list.size(); i++)
		// temp = $urandom_range(1,11);
		temp = (($urandom(seed)) + 1);
		rand_int_list[i] = temp - 1;
		success = (temp && success);
	   if(success == 0)
	     return 0;
      if (rand_bit_list.size() > 0)
	   for (int i = 0; i < rand_bit_list.size(); i++)
		rand_bit_list[i] = temp - 1;
	   if(success == 0)
	     return 0;
	     return 1;
   endfunction: my_randomize
endclass: base_transaction
```verilog
I have the following class which extend the base class:
class tx_transaction extends base_transaction;
   bit [15:0] data_xi;
   bit [15:0] data_xq;
   int mem_int = 2, mem_int_a = 5; //TODO- delete
   //uvm_object_utils\
   `uvm_object_utils(tx_transaction)
   //constructor
   function new(string name = "tx_transaction");
      super.new(name);
   endfunction: new
   function void add_rand_macro();
      add_rand_int(mem_int);
      add_rand_int(mem_int_a);
   endfunction: add_rand_macro
   //TODO - DELETE
   function void foo();
      $display("rand mem int: %d %d", mem_int, mem_int_a);
   endfunction: foo
endclass: tx_transaction
I call the following function from the sequence (tx\_trx - is tx\_transaction instance, and i is iterator):
```verilog
	 tx_trx.add_rand_macro();
                 tx_trx.my_randomize(i+1);
	         tx_trx.foo();
For some reason the foo function display allwas 2 5 (memt\_int, mem\_int\_a), though those values are updated by the my\_randomize function (which random the array which the member class are passed by ref)
**Author:** ![DigvijaysinhSuryavanshi](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/d/839c29/32.png) [@DigvijaysinhSuryavanshi](https://verificationacademy.com/forums/u/DigvijaysinhSuryavanshi)\
**Post date:** [December 15, 2016, 10:19am UTC](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/2 "2016-12-15T10:19:18Z")
</div>
_In reply to [saritr](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652):_
Hi saritr,
Consider following sample example to understand issue.
In your code “my\_randomize” operates on queue list ‘rand\_int\_list’ but not directly on passed ref arguments [mem\_int, mem\_int\_a].
If you want randomized values to get reflected inside your foo() method.
Option1 : Perform randomization on class objects instead using queue of int/bit type.
Option2 : Do randomization directly on [mem\_int, mem\_int\_a] variables instead
storing them first in queue and then randomizing queue elements.
```auto
typedef class test_ext;
class tets_c;
  int a=6;
  int int_q[$];
  test_ext test_q[$];
  function add_int(ref int val);
    int_q.push_back(val);
  function randomize_int();
     int_q[0]=$urandom_range(11,15);
  function add_obj(ref test_ext obj);
    test_q.push_back(obj);
  function randomize_class();
    test_q[0].a=$urandom_range(21,25);
class test_ext extends tets_c;
  function new() ;
    this.a=8;
  function foo();
    $display("int_q a %0d Actual a %0d",int_q[0], a);
    $display("test_q a %0d Actual a %0d",test_q[0].a,a);
  module m;
    test_ext t;
      t=new();
      t.add_int(t.a);
      t.add_obj(t);
      t.foo();
      t.randomize_int();
      t.foo();
      t.randomize_class();
      t.foo();
**Post date:** [December 15, 2016, 12:03pm UTC](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/3 "2016-12-15T12:03:33Z")
</div>
_In reply to [DigvijayS](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/2):_
Hey DigvijayS,
I can’t use this example because each transaction will have its own member.
For example:
```verilog
   bit [15:0] data_xi;
   bit [15:0] data_xq;
class rx_transaction extends base_transaction;
   bit [15:0] data_xi;
   bit xq;
   int delay =3, val = 5, num= 8; //TODO- delete
endclass: rx_transaction
**Post date:** [December 15, 2016, 12:29pm UTC](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/4 "2016-12-15T12:29:59Z")
</div>
_In reply to [saritr](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/3):_
Hi saritr,
Above example is for reference only to identify an issue.
Preferred approach to solve this will be to use _**In-line constraints — randomize() with**_,a system verilog construct !!
**Post date:** [December 15, 2016, 1:54pm UTC](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/5 "2016-12-15T13:54:45Z")
</div>
_In reply to [DigvijayS](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/4):_
I can’t use In-line constraints — randomize() because I use modelSim.
The question is if there is any way to get what I want - that “my\_randomize” operates on directly on passed ref arguments [mem\_int, mem\_int\_a]…
**Author:** ![Chandra\_Bhushan\_Singh](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/c/73ab20/32.png) [@Chandra\_Bhushan\_Singh](https://verificationacademy.com/forums/u/Chandra_Bhushan_Singh)\
**Post date:** [December 22, 2016, 1:29pm UTC](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/6 "2016-12-22T13:29:04Z")
</div>
_In reply to [saritr](https://verificationacademy.com/forums/t/value-of-member-class-are-not-updated/32652/5):_
Saritr:
Pass by reference does not work like as you are trying to implement. Function add\_rand\_int(mem\_int); add\_rand\_int(mem\_int\_a); scope is completed when they return. Now in queue values which you store does not pointing to mem int and mem\_int\_a. You need to modify the function.
