# UVM register model: strange uvm\_error message
**URL:** <https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512>\
**Category:** UVM\
**Tags:** uvm-register-sequences, UVM, error, UVM-Register-Built-in-sequence, UVM-system-verilog\
**Created:** [April 1, 2015, 9:30am UTC](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512 "2015-04-01T09:30:19Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![Mustafa](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/m/f19dbf/32.png) [@Mustafa](https://verificationacademy.com/forums/u/Mustafa)\
**Post date:** [April 1, 2015, 9:30am UTC](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/1 "2015-04-01T09:30:19Z")
</div>
Hello,
I get the following error when running the sequence uvm\_reg\_bit\_bash\_seq
UVM\_ERROR verilog\_src/uvm-1.1d/src/reg/sequences/uvm\_reg\_bit\_bash\_seq.svh(175): rgm\_seq.reg\_single\_bit\_bash\_seq [uvm\_reg\_bit\_bash\_seq] Writing a 0 in bit #0 of register “spi\_rm.reg\_0x0” with initial value 'h0000000000000001 yielded 'h0000000000000000 instead of 'h0000000000000001
The message states a correct action, writing 0 in bit #0 with initial value 'h01 yielded 'h00. So why does the sequence expect the value to be 'h01 instead of the correct one, which is 'h00 ?
**Author:** ![Tudor\_Timi](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/tudor_timi/32/1897_2.png) [@Tudor\_Timi](https://verificationacademy.com/forums/u/Tudor_Timi)\
**Post date:** [April 1, 2015, 12:05pm UTC](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/2 "2015-04-01T12:05:55Z")
</div>
_In reply to [Mustafa](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512):_
Are you sure the field isn’t declared as read-only?
**Post date:** [April 1, 2015, 12:32pm UTC](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/3 "2015-04-01T12:32:06Z")
</div>
_In reply to [Tudor Timi](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/2):_
Yes, I’m sure
By the way for “RO” fields a message similar to this may be displayed normally, but as an uvm\_info not uvm\_error as in my case.
i.e a an observed write transaction followed by an observed read transaction with no value change
In my case, the uvm\_error message itself has contradiction
**Post date:** [April 1, 2015, 12:57pm UTC](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/4 "2015-04-01T12:57:50Z")
</div>
_In reply to [Mustafa](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/3):_
The problem is for all “RW” fields
Another example:
UVM\_ERROR verilog\_src/uvm-1.1d/src/reg/sequences/uvm\_reg\_bit\_bash\_seq.svh(175) @ 143600000000: rgm\_seq.reg\_single\_bit\_bash\_seq [uvm\_reg\_bit\_bash\_seq] Writing a 1 in bit #1 of register “spi\_rm.reg\_0x27” with initial value 'h0000000000000020 yielded 'h0000000000000022 instead of 'h0000000000000020
What is stated is correct, so why does it consider it as an error?
**Author:** ![Vinay\_Jain](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/vinay_jain/32/3037_2.png) [@Vinay\_Jain](https://verificationacademy.com/forums/u/Vinay_Jain)\
**Post date:** [April 2, 2015, 5:48am UTC](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/5 "2015-04-02T05:48:14Z")
</div>
_In reply to [Mustafa](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/4):_
@Mustafa,
```verilog
UVM_ERROR verilog_src/uvm-1.1d/src/reg/sequences/uvm_reg_bit_bash_seq.svh(175): rgm_seq.reg_single_bit_bash_seq [uvm_reg_bit_bash_seq] Writing a 0 in bit #0 of register "spi_rm.reg_0x0" with initial value 'h0000000000000001 yielded 'h0000000000000000 instead of 'h0000000000000001
Only reason sequence throwing message if reg\_0x0 bit#0 is RO. Check it in your simulation and regfile if bit#0 is RO.
Sometime back my team also used to get such error, finally we found that access\_type in regfile is different than what it was in DUT.
BTW, please use code tags for better reading :)
**Post date:** [April 2, 2015, 9:57am UTC](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/6 "2015-04-02T09:57:34Z")
</div>
_In reply to [Vinay Jain](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/5):_
Hi Vinay Jain,
I appreciate it if we investigate the message again.
It says:
```auto
writing 0 in bit #0 of a register with initial value 'h01 yielded 'h00
which means in the RTL, the register is RW.
I’ve checked the register classes and made sure the field is defined as “RW”. Actually the whole register’s fields are defined as “RW”. So why the sequence expects the result to be 'h01 instead of the correct one 'h00 !
**Author:** ![DhavalPandya](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/d/5f9b8f/32.png) [@DhavalPandya](https://verificationacademy.com/forums/u/DhavalPandya)\
**Post date:** [November 28, 2017, 8:19am UTC](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/7 "2017-11-28T08:19:53Z")
</div>
_In reply to [Mustafa](https://verificationacademy.com/forums/t/uvm-register-model-strange-uvm-error-message/30512/6):_
Hi Mustafa,
Did you find solution for this issue ?
Because I am also facing same issue. The field is RW, even though it is giving such error.
Regards,
Dhaval
