# Uvm reg read from uvm-monitor
**URL:** <https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291>\
**Tags:** UVM\
**Created:** [September 21, 2016, 12:36am UTC](https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291 "2016-09-21T00:36:59Z")\
**Showing post:** 29
**Author:** ![sa5691](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/7feea3/32.png) [@sa5691](https://verificationacademy.com/forums/u/sa5691)\
**Post date:** [May 20, 2021, 6:12am UTC](https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291/29 "2021-05-20T06:12:50Z")
_In reply to [yuvraj khare](https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291/28):_
That is the reason we ask to show the full code here so that we can help you out. In the example you have shown there is no way i can know what is there inside your reg\_model class and lot of other things missing. How would you expect someone to help and figure out your error unless you show full scenario or codes.
_[View the full topic](https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291)._
