# Uvm reg read from uvm-monitor
**URL:** <https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291>\
**Tags:** UVM\
**Created:** [September 21, 2016, 12:36am UTC](https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291 "2016-09-21T00:36:59Z")\
**Showing post:** 22
**Author:** ![yuvraj\_khare](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/y/e99b99/32.png) [@yuvraj\_khare](https://verificationacademy.com/forums/u/yuvraj_khare)\
**Post date:** [May 19, 2021, 7:49am UTC](https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291/22 "2021-05-19T07:49:32Z")
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291/21):_
I am also facing the same issue when using the ral model for read the register in my uvm\_monitor am getting an error:
Error-[IOUCM] Illegal use of class method
/$PROJ\_DIR/hxtop\_interrupt\_monitor.sv
Though as of nowam using ral model in my TB and all the registers sequences are working fine.
Can you please suggest me wat go wrong here?
_[View the full topic](https://verificationacademy.com/forums/t/uvm-reg-read-from-uvm-monitor/32291)._
