# UVM Phase Synchronization
**URL:** <https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852>\
**Category:** UVM\
**Tags:** UVM\
**Created:** [December 22, 2017, 11:09am UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852 "2017-12-22T11:09:24Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![mitesh.patel](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/m/7cd45c/32.png) [@mitesh.patel](https://verificationacademy.com/forums/u/mitesh.patel)\
**Post date:** [December 22, 2017, 11:09am UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/1 "2017-12-22T11:09:24Z")
</div>
Hello,
   I am having question related to phase synchronization in uvm. let me explain by code.
1. my driver class has following phases.
build\_phase, reset\_phase, configure\_phase, main\_phase
```verilog
     class my_driver extends uvm_driver;
      function new ********************
     function build_phase(uvm_phase phase);
         // Necessary logic
     endfunction : build_phase
     task reset_phase(uvm_phase phase);
         // Necessary logic
     endtask : reset_phase
    task configure_phase(uvm_phase phase);
         // Necessary logic
     endtask : configure_phase
    task main_phase(uvm_phase phase);
         // Necessary logic
     endtask : main_phase
     endclass : my_driver
1. my monitor class has following phases.
build\_phase and run\_phase.
```verilog
   class my_monitor extends uvm_monitor;
         // Necessary logic
         // Necessary logic
        /* I want to add logic here, which can detect uvm phases of other class,*/
     endtask : run_phase
     endclass : my_monitor
i want to synchronize main\_phase of driver class with run\_phase of monitor class. my requirement is [b]run\_phase of monitor class only start executing when main\_phase of driver class is started. is there any mechanism for such issue in uvm?
or is there any mechanism by which i can know which phase is executing?
Please let me know if more details are required from my side.
Thanks in advance.
Mitesh N.Patel
**Post date:** [December 22, 2017, 12:11pm UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/2 "2017-12-22T12:11:24Z")
</div>
_In reply to [mitesh.patel](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852):_
You want to mix the run-subphases, like reset\_phase, configure\_phase etc., with the run\_phase. This is a bad approach. If you have reasons to deal with the sub-phases Of UVM you should do this in all components. The best solution is to use in your monitor main\_phase instead of run\_phase.
But I’m not sure that you really need the sub-phases of the run\_phase. The key question is, what do you want to do in these phases.
**Post date:** [December 25, 2017, 12:19pm UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/3 "2017-12-25T12:19:21Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/2):_
Hi chr\_sue,
Thanks for response, i know that this approach is not recommended. but in my environment, developed VIPs are having run_phases and i have to reuse that VIPs. and i can not simply use run_phase, i have to compulsory use, 13 phases parallel with run_phase. so is there any mechanism in UVM, by which i can control over above situation?
Thanks in Advance
Mitesh N. Patel
**Post date:** [December 25, 2017, 6:28pm UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/4 "2017-12-25T18:28:05Z")
</div>
_In reply to [mitesh.patel](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/3):_
Do you really need the reset\_phase, configure\_phase etc.?
Could you please explain why? You can perform a reset and the configuration using reset sequences and configuration sequences while running the run\_phase only.
**Author:** ![sharvil111](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/sharvil111/32/3790_2.png) [@sharvil111](https://verificationacademy.com/forums/u/sharvil111)\
**Post date:** [December 26, 2017, 3:40am UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/5 "2017-12-26T03:40:28Z")
</div>
As suggested by _chr\_sue_, the usage of **mixed-phases is not recommended practice**. Still if you have constraints of **multiple phase usage** , then **you can make use of _wait\_for\_state_ API of UVM phase**.
The _uvm\_phase_ class provides the “_wait\_for\_state_” task to **wait till a particular state of phase is reached**. All you need to do is **get a handle of implementation of a phase and call the API**.
In the _build\_phase_ of _monitor_, **get the handle of _main\_phase_ implementation**. Thereafter, in the _run_ phase, **call the wait task to wait till _driver_ reaches main phase**.
```verilog
// Get handle of main phase in monitor
uvm_phase p;
p = phase.find_by_name("main",0);
// find_by_name prototype
// extern function uvm_phase find_by_name(string name, bit stay_in_scope=1);
// Call wait task in monitor run phase
p.wait_for_state(UVM_PHASE_STARTED);
// wait_for_state prototype
// extern task wait_for_state(uvm_phase_state state, uvm_wait_op op=UVM_EQ);
Note that this works in a single phase domain, I have not tested it across multiple domains. Following is an example of how the wait task is invoked to block the monitor.
```verilog
  class driver extends uvm_component;
    `uvm_component_utils(driver)
    function new(string name = "driver",uvm_component parent = null);
      super.new(name,parent);
      phase.raise_objection(this);
      #5;
      $display($time,"\tdriver: reset phase ended");
      phase.drop_objection(this);
  class monitor extends uvm_component;
    uvm_phase p;
    `uvm_component_utils(monitor)
    function new(string name = "monitor",uvm_component parent = null);
      if(p == null) $display("P found null");
      $display($time,"\tMonitor unblocked");
  // Output
  UVM_INFO @ 0: reporter [RNTST] Running test test...
                     5	driver: reset phase ended
                     5	Monitor unblocked
  UVM_INFO /apps/vcsmx/etc/uvm-1.1/src/base/uvm_objection.svh(1267) @ 5: reporter [TEST_DONE] 'run' phase is ready to proceed to the 'extract' phase
For more information refer to [uvm\_phase.svh](https://verificationacademy.com/verification-methodology-reference/uvm/docs_1.2/html/src/base/uvm_phase.svh) and [uvm\_phase singletons question](http://forums.accellera.org/topic/1769-uvm-phase-singletons/). [This blog post](http://blog.verificationgentleman.com/2014/04/uvm-drain-time-old-fashioned-way.html) might also be useful.
**Post date:** [December 26, 2017, 4:16am UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/6 "2017-12-26T04:16:09Z")
</div>
_In reply to [sharvil111](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/5):_
Thanks sharvil111 and chr\_sue for response.
i used same code as mentioned by you. but not getting expected output. here i am attaching code. please let me know if i misunderstood, i am using VCS tool for compile and run the simulation.
class driver extends uvm\_component;
`uvm\_component\_utils(driver)
function new(string name = “driver”,uvm\_component parent = null);
  #5;
class monitor extends uvm\_component;
uvm\_phase p;
class test extends uvm\_test;
`uvm\_component\_utils(test)
  super.new(name, parent);
driver drv;
monitor mon;
  uvm_config_db#(int)::set(this, "drv", "delay", 10);
  uvm_config_db#(int)::set(this, "mon", "delay", 100);
  drv = driver::type_id::create("drv", this);
  mon = monitor::type_id::create("mon", this);
function void start_of_simulation_phase(uvm_phase phase);
  //this.set_report_verbosity_level_hier(UVM_HIGH);
import uvm\_pkg::\*;
initial
run\_test(“test”);
Output:-
(Specify +UVM\_NO\_RELNOTES to turn off this notice)
UVM\_INFO @ 0: reporter [RNTST] Running test test…
0 Monitor unblocked
UVM\_INFO /apps/vcsmx/etc/uvm-1.2/src/base/uvm\_objection.svh(1270) @ 0: reporter [TEST\_DONE] ‘run’ phase is ready to proceed to the ‘extract’ phase
UVM\_INFO /apps/vcsmx/etc/uvm-1.2/src/base/uvm\_report\_server.svh(847) @ 5: reporter [UVM/REPORT/SERVER]
**Post date:** [December 26, 2017, 4:48am UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/7 "2017-12-26T04:48:34Z")
</div>
_In reply to [mitesh.patel](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/6):_
The same code works for me. It blocks monitor for 5ns.
```verilog
                   5	Monitor unblocked
Please find the code at [Edit code - EDA Playground](https://www.edaplayground.com/x/29xA) . Note that I am also using VCS with UVM-1.1d (and UVM-1.2).
**Post date:** [December 26, 2017, 5:05am UTC](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/8 "2017-12-26T05:05:44Z")
</div>
_In reply to [sharvil111](https://verificationacademy.com/forums/t/uvm-phase-synchronization/33852/7):_
Yeah sharvil111,
It is working fine.
Mitesh N. Patel
