# Uvm\_info not getting displayed but $display does
**URL:** <https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061>\
**Category:** UVM\
**Tags:** UVM, UVM\_VERBOSITY, uvm\_macro, UVM\_INFO-component-name-meaningless\
**Created:** [September 10, 2020, 10:19pm UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061 "2020-09-10T22:19:08Z")\
**Posts on this page:** 11\
**Page:** 1
<div class="post-metadata">
**Author:** ![NimishaV](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/n/f1d935/32.png) [@NimishaV](https://verificationacademy.com/forums/u/NimishaV)\
**Post date:** [September 10, 2020, 10:19pm UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/1 "2020-09-10T22:19:08Z")
</div>
I have this following function called from a property, in which if I use uvm\_info it is not displayed but $display gets displayed.
function void display(int expected\_cycles, int actual\_cycles);
`uvm\_info(" PROPERTY",$sformatf(" THROUGHPUT: actual\_cycles %0d expected\_cycles %0d",actual\_cycles,expected\_cycles) ,UVM\_LOW)
$display(" THROUGHPUT: actual\_cycles %0d expected\_cycles %0d",actual\_cycles,expected\_cycles);
Also, I tried using uvm\_info along with assert, even that didn’t work! I have also imported uvm\_pkg and included uvm macros file.
assert property (throughput) else `uvm\_info(“PROPERTY FAILURE”,$sformatf(“THROUGHPUT PROPERTY FAILED”) ,UVM\_LOW);
The +UVM\_VERBOSITY IS SET TO UVM\_NONE
+UVM\_VERBOSITY=UVM\_NONE before running the regression.
Please help!
**Author:** ![logie](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/l/74df32/32.png) [@logie](https://verificationacademy.com/forums/u/logie)\
**Post date:** [September 11, 2020, 1:31am UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/2 "2020-09-11T01:31:11Z")
</div>
_In reply to [Nimisha Varadkar](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061):_
Remove the +UVM\_VERBOSITY setting… By default it goes to UVM\_MEDIUM.
**Post date:** [September 11, 2020, 2:03am UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/3 "2020-09-11T02:03:24Z")
</div>
_In reply to [logie](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/2):_
It’s set to UVM\_NONE.
**Post date:** [September 11, 2020, 2:26am UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/4 "2020-09-11T02:26:18Z")
</div>
_In reply to [Nimisha Varadkar](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/3):_
I think this is the reason why nothing is printing out… You have set verbosity to “none”. Either remove it or set it to UVM\_MEDIUM.
**Post date:** [September 11, 2020, 2:44am UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/5 "2020-09-11T02:44:02Z")
</div>
_In reply to [logie](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/4):_
Isn’t statement with UVM\_NONE always printed?
**Post date:** [September 11, 2020, 7:39am UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/6 "2020-09-11T07:39:59Z")
</div>
_In reply to [Nimisha Varadkar](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/5):_
Try using `uvm_error instead of `uvm\_info. There is not verbosity setting for errors. I would also try uvm\_report\_error() direectly instead of using the macro.
**Post date:** [September 11, 2020, 5:51pm UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/7 "2020-09-11T17:51:52Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/6):_
Thanks, Dave! UVM\_ERROR worked!
**Author:** ![TC\_2017](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/t/53a042/32.png) [@TC\_2017](https://verificationacademy.com/forums/u/TC_2017)\
**Post date:** [September 11, 2020, 6:41pm UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/8 "2020-09-11T18:41:56Z")
</div>
_In reply to [Nimisha Varadkar](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/7):_
When you set the verbosity ( via the command line switch ) using +UVM\_VERBOSITY=UVM\_NONE
**Only statements with verbosity of UVM\_NONE get displayed .**
Since you have a verbosity of UVM\_LOW for the `uvm\_info
in the initial code , it will Never be displayed .
**Post date:** [September 11, 2020, 6:54pm UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/9 "2020-09-11T18:54:36Z")
</div>
_In reply to [TC\_2017](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/8):_
Thanks for the insight!
**Post date:** [September 11, 2020, 8:25pm UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/10 "2020-09-11T20:25:27Z")
</div>
_In reply to [TC\_2017](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/9):_
> _In reply to [Nimisha Varadkar](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/9):_
BUT the standard is saying (F.2.2.4 uvm\_verbosity):
UVM\_NONE—The report is always printed (NONE = 0); the verbosity level setting cannot disable it.
**Post date:** [September 11, 2020, 8:35pm UTC](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/11 "2020-09-11T20:35:32Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/uvm-info-not-getting-displayed-but-display-does/38061/10):_
Christoph, please read the posts more carefully. The `uvm\_info message was using UVM\_LOW, which is higher than UVM\_NONE, so that message was getting filtered.
