# UVM Framework Course - Two New Sessions Now Available
**URL:** <https://verificationacademy.com/forums/t/uvm-framework-course-two-new-sessions-now-available/36526>\
**Category:** Announcements\
**Tags:** UVMF, UVM-Framework, Announcements, Course, Bob-Oden\
**Created:** [September 10, 2019, 2:53pm UTC](https://verificationacademy.com/forums/t/uvm-framework-course-two-new-sessions-now-available/36526 "2019-09-10T14:53:03Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![Administrator1](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/a/e9c0ed/32.png) [@Administrator1](https://verificationacademy.com/forums/u/Administrator1)\
**Post date:** [September 10, 2019, 2:53pm UTC](https://verificationacademy.com/forums/t/uvm-framework-course-two-new-sessions-now-available/36526/1 "2019-09-10T14:53:03Z")
</div>
### **Are you a Design or Verification Engineer or Manager interested in the UVM Framework?**
**Two new UVMF sessions now available on the Verification Academy, by UVM Field Specialist [Bob Oden](https://verificationacademy.com/users/bob-oden "Subject Matter Expert - Bob Oden").**
**[Code Generation Guidelines](https://verificationacademy.com/sessions/code-generation-guidelines "Code Generation Guidelines - UVM Framework")**
In this session, you will be given an overview of the flow used to generate a working simulation using the UVMF code generator. In addition, we will also cover best practices for using the code generator and how to avoid common mistakes.
**[Stimulus and Analysis Data Flow](https://verificationacademy.com/sessions/stimulus-and-analysis-data-flow "Stimulus and Analysis Data Flow - UVM Framework")**
In this session, you will be given an overview of the stimulus and analysis flow within the UVM Framework. You will also learn the movement of data from sequences to the driver BFM and back as well as from the monitor BFM to the agent analysis port.
**Login with your Full Access account to [view or download](https://verificationacademy.com/courses/UVM-Framework-One-Bite-at-a-Time "New Sessions - UVM Framework - One Bite at a Time").**
