# UVM\_DRIVER- Driving an interface at an event
**URL:** <https://verificationacademy.com/forums/t/uvm-driver-driving-an-interface-at-an-event/35833>\
**Category:** UVM\
**Tags:** analysis-port, SystemVerilog, UVM, System-Veriilog-Events\
**Created:** [March 8, 2019, 5:15pm UTC](https://verificationacademy.com/forums/t/uvm-driver-driving-an-interface-at-an-event/35833 "2019-03-08T17:15:49Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![PoojaPathak](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/p/76d3ee/32.png) [@PoojaPathak](https://verificationacademy.com/forums/u/PoojaPathak)\
**Post date:** [March 8, 2019, 5:15pm UTC](https://verificationacademy.com/forums/t/uvm-driver-driving-an-interface-at-an-event/35833/1 "2019-03-08T17:15:49Z")
</div>
My agent needs to drive a “done” signal when any some input is received on any one of the two input interfaces. I am using analysis ports to get input transactions and pushing that data on a queue for both cases. I tried to use the event data type but am not able to properly drive the done signal.
```auto
input1_data_type _input1[$];
    input2_data_type _input2[$];
    event input1_received;
    event input2_received;
    virtual function void write_input1 (input1_data_type _trans);
        _input1.push_back(_trans);
        ->input1_received;
    endfunction: write_input1
    virtual function void write_input2 (input2_data_type _trans);
        _input2.push_back(_trans);
        ->input2_received;
    endfunction: write_input2
    //Not showing the build_phase where I retrieve the interfaces and connect the analysis ports.
    virtual task run_phase (uvm_phase phase);
        super.run_phase(phase);
            //Other tasks
            drive_done();
        join_none
    endtask: run_phase
        virtual task drive_done();
        forever begin
            @(input1_received.triggered || input2_received.triggered)
                output_interface_vif.done <= 1'b1;
The above code does not drive the done back to 0 at the next clock. Note I am not able to compile with “##1” as I get the error:
> Cycle delay operator requires a default clocking to be specified for
> module/interface/program ‘vcs\_paramclassrepository’.
The clk and reset are not driven by this agent and I think I can’t specify the timeunit(which I think is what the error is indicating) in this class as it is central to the whole testbench and is likely to change.
I also tried the following but it is not driving interface at all even though I can see transactions being pushed on the queue.
```auto
        forever begin
            @(output_interface_vif.monitor.clk);
            if(input1_received.triggered || input2_received.triggered)
                output_interface_vif.done <= 1'b0;
Can someone suggest a good way to make this work?
**Post date:** [March 8, 2019, 6:58pm UTC](https://verificationacademy.com/forums/t/uvm-driver-driving-an-interface-at-an-event/35833/2 "2019-03-08T18:58:38Z")
</div>
_In reply to [Pooja Pathak](https://verificationacademy.com/forums/t/uvm-driver-driving-an-interface-at-an-event/35833):_
To be clear, are you writing SV or UVM code?
I see only SV code.
Of course you can use any SV construct in the UVM. But it is recommended to ue the UVM consructs like uvm\_event and instead of queues the uvm\_tlm\_fifo.
The cycle delay operator (##1) might not be supported by VCS. Instead you could use a task which is providing this delay.
```verilog
task automatic cycles(int unsigned N);
  repeat (N) @(output_interface_vif.monitor.clk);
