# UVM driver blocks handshake to finish\_item when run\_phase spawns processes by "fork" "join\_none"
**URL:** <https://verificationacademy.com/forums/t/uvm-driver-blocks-handshake-to-finish-item-when-run-phase-spawns-processes-by-fork-join-none/33150>\
**Tags:** UVM, UVM-driver-fork-join\_none-simulation-stops\
**Created:** [May 24, 2017, 7:18am UTC](https://verificationacademy.com/forums/t/uvm-driver-blocks-handshake-to-finish-item-when-run-phase-spawns-processes-by-fork-join-none/33150 "2017-05-24T07:18:25Z")\
**Showing post:** 2
**Post date:** [May 24, 2017, 7:34am UTC](https://verificationacademy.com/forums/t/uvm-driver-blocks-handshake-to-finish-item-when-run-phase-spawns-processes-by-fork-join-none/33150/2 "2017-05-24T07:34:03Z")
_In reply to [dario.dellaquia](https://verificationacademy.com/forums/t/uvm-driver-blocks-handshake-to-finish-item-when-run-phase-spawns-processes-by-fork-join-none/33150):_
Could you please explain why you are using the events?
What does it mean:
```verilog
blocking_event_p;
An Event can be triggered or you can synchronize on a trigger with @ or wait.
_[View the full topic](https://verificationacademy.com/forums/t/uvm-driver-blocks-handshake-to-finish-item-when-run-phase-spawns-processes-by-fork-join-none/33150)._
