# Uvm data flow and handshaking
**URL:** <https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066>\
**Category:** UVM\
**Tags:** UVM, get\_next\_item-handshaking-uvm\
**Created:** [September 25, 2015, 4:04pm UTC](https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066 "2015-09-25T16:04:25Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![ningyangverificationacademy](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/n/85e7bf/32.png) [@ningyangverificationacademy](https://verificationacademy.com/forums/u/ningyangverificationacademy)\
**Post date:** [September 25, 2015, 4:04pm UTC](https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066/1 "2015-09-25T16:04:25Z")
</div>
I am learning UVM and this is a test program I wrote. So in the uvm\_drv, there is a infinity blocking loop asking data from sequence. In sequence class, anything between “start\_item” and “finish\_item” will be passed to driver? How does the handshaking exactly happen here?
When I compile this code, I got an error message saying:
UVM\_INFO top.sv(162) @ 0: reporter [top] I’m alive
UVM\_INFO @ 0: reporter [RNTST] Running test test1…
UVM\_INFO top.sv(111) @ 0: uvm\_test\_top.e.a [agent] starting sequence
UVM\_INFO top.sv(53) @ 0: uvm\_test\_top.e.a.s [seqencer] sequencer body
UVM\_INFO top.sv(73) @ 0: uvm\_test\_top.e.a.d [drv] I am in run phase
UVM\_INFO top.sv(76) @ 0: uvm\_test\_top.e.a.d [drv] I am in forever loop
UVM\_INFO top.sv(34) @ 0: uvm\_test\_top.e.a.s@@trans [sequence] sequence body
dst=054097bd, crc=7e261e9c
UVM\_FATAL @ 0: uvm\_test\_top.e.a.s [s] send\_request failed to cast sequence item
— UVM Report catcher Summary —
How should I make it correct? Thanks a lot.
```verilog
  1 // include package
  2 `include "uvm_macros.svh"
  3
  4 package usr_pkg;
  5
  6 import uvm_pkg::*;
  8 class pkt extends uvm_sequence_item;
  9 rand int dst;
 10 rand int crc;
 11
 12 function new (string name ="pkt");
 13 super.new(name);
 14 endfunction
 15
 16 `uvm_object_utils(pkt)
 17 endclass
 20 class trans extends uvm_sequence #(pkt);
 21 pkt p;
 22
 23 function new (string name = "trans");
 24 super.new("trans");
 25 endfunction
 26
 27 `uvm_object_utils (trans)
 28
 29 task body();
 30
 31 pkt p = pkt::type_id::create("p");
 32
 33 start_item(p);
 34 `uvm_info ("sequence", "sequence body", UVM_MEDIUM);
 35 if (!(p.randomize())) `uvm_info ("sequence", "bad randomization", UVM_MEDIUM);
 36 $display ("dst=%h, crc=%h",p.dst, p.crc);
 37 finish_item(p);
 38 endtask
 39
 40 endclass
 43 class sqr extends uvm_sequencer #(trans);
 44 `uvm_component_utils (sqr)
 45
 46 trans t;
 47
 48 function new (string name, uvm_component parent);
 49 super.new(name, parent);
 50 endfunction
 51
 52 task run_phase(uvm_phase phase);
 53 `uvm_info ("seqencer", "sequencer body", UVM_MEDIUM);
 54 endtask
 55
 56 endclass
 57
 58
 59 class drv extends uvm_driver #(trans);
 60 `uvm_component_utils (drv)
 61
 62 trans t;
 63
 64 function new (string name, uvm_component parent);
 65 super.new(name, parent);
 66 endfunction
 67
 68 function void build_phase(uvm_phase phase);
 69 super.build_phase (phase);
 70 endfunction
 71
 72 task run_phase (uvm_phase phase);
 73 `uvm_info ("drv", "I am in run phase", UVM_MEDIUM);
 74
 75 forever begin
 76 `uvm_info ("drv", "I am in forever loop", UVM_MEDIUM);
 77 seq_item_port.get_next_item(t);
 78 `uvm_info ("drv", "ph", UVM_MEDIUM);
 79 seq_item_port.item_done();
 80 end
 81
 82 endtask
 83 endclass
 86 class agnt extends uvm_agent;
 87 `uvm_component_utils (agnt)
 88
 89 trans t;
 90 sqr s;
 91 drv d;
 92
 93 function new (string name, uvm_component parent);
 94 super.new(name, parent);
 95 endfunction
 96
 97 function void build_phase (uvm_phase phase);
 98 super.build_phase(phase);
 99 s = sqr::type_id::create ("s", this);
100 d = drv::type_id::create ("d", this);
101 endfunction
102
103 function void connect_phase (uvm_phase phase);
104 super.connect_phase(phase);
105 d.seq_item_port.connect (s.seq_item_export);
106 endfunction
107
108 task run_phase(uvm_phase phase);
109 t=trans::type_id::create("t");
110 phase.raise_objection(this, "starting");
111 `uvm_info ("agent", "starting sequence", UVM_MEDIUM);
112 t.start(s);
113 #1000;
114 `uvm_info ("agent", "ending sequence", UVM_MEDIUM);
115
116 phase.drop_objection(this, "ending");
117 endtask
118
119 endclass
122 class env extends uvm_env;
123 `uvm_component_utils(env)
124 agnt a;
125
126 function new (string name, uvm_component parent);
127 super.new (name, parent);
128 endfunction
129
130 function void build_phase(uvm_phase phase);
131 super.build_phase (phase);
132 a=agnt::type_id::create("a", this);
133 endfunction
134
135 endclass
136
137 class test1 extends uvm_test;
138 `uvm_component_utils(test1)
139 env e;
140
141 function new (string name, uvm_component parent);
142 super.new (name, parent);
143 endfunction
144
145 function void build_phase(uvm_phase phase);
146 super.build_phase (phase);
147 e=env::type_id::create("e", this);
148 endfunction
149
150 endclass
151
152
153 endpackage
154
155
156 module top ();
157
158 import uvm_pkg::*;
159 import usr_pkg::*;
160
161 initial begin
162 `uvm_info ("top", "I'm alive", UVM_MEDIUM);
163 run_test();
164 end
165
166 endmodule
**Author:** ![AnPham](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/a/f9ae1b/32.png) [@AnPham](https://verificationacademy.com/forums/u/AnPham)\
**Post date:** [September 25, 2015, 5:15pm UTC](https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066/2 "2015-09-25T17:15:10Z")
</div>
_In reply to [ningyangverificationacademy](https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066):_
You are misunderstanding _sequence_ and _transaction_.
The sequencer and driver should be declared as:
```verilog
class sqr extends uvm_sequencer #(pkt);
class drv extends uvm_driver #(pkt);
**Post date:** [September 27, 2015, 9:17pm UTC](https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066/3 "2015-09-27T21:17:34Z")
</div>
_In reply to [An Pham](https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066/2):_
Thanks a lot. That solves my problem, and I am starting to make sense how things work in UVM
**Post date:** [September 28, 2015, 4:11am UTC](https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066/4 "2015-09-28T04:11:42Z")
</div>
_In reply to [ningyangverificationacademy](https://verificationacademy.com/forums/t/uvm-data-flow-and-handshaking/31066/3):_
If you want to understand how the hand-shaking between driver and sequencer works, you could find it inside the UVM cookbook or this website:
[http://cluelogic.com/2012/11/uvm-tutorial-for-candy-lovers-sequence-item-port/](http://cluelogic.com/2012/11/uvm-tutorial-for-candy-lovers-sequence-item-port/)
